Author Topic: Loud Bang when braking hard  (Read 3816 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« on: 11 July 2013, 13:43 »
Had to do emergency stop about week ago and again yesterday and there was a loud bang/pop, thought my tyre had blown or something had gone on the brakes but checked it all and everything is fine.
Also passed MOT week ago and had new lower arms and bushes put on so can't be any issues with the brakes or suspension can it??
One thing I did notice was an eggy smell after the second time kinda catalytic converter smell but then it could of been something in the air?!?!
Any ideas??
Baffled and slightly worried  :huh:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Loud Bang when braking hard
« Reply #1 on: 11 July 2013, 14:33 »
Could it be something as simple like you had a bottle of water in the boot?
Offline Perryd84
« Reply #2 on: 11 July 2013, 14:44 »
Definitely something at the front end, boots empty.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 11 July 2013, 14:52 »
I would say rear lower arm bolts need tightening. If you're breaking hard they've probably moved forward with the momentum
Offline Perryd84
« Reply #4 on: 11 July 2013, 15:12 »
Nice one wazzer I'll check them out tonight. Anything at the front end I could check as well? Wouldn't be the mounts would it?
Offline mar_k
« Reply #5 on: 11 July 2013, 17:02 »
My money is on soft/worn rear lower arm bush,
Under harsh braking the bush turnt inside out and allowed the lower arm to hit the sub frame.
Offline golfyste
  • Project track car
« Reply #6 on: 12 July 2013, 13:45 »
As said check lower arm bolts but also all other subframe bolts and also gearbox mount and dogbone mount  :cool:
Offline Perryd84
« Reply #7 on: 12 July 2013, 15:15 »
Thanks for the pointers didn't get chance to crawl under the car last night so i will check tonight or most likely tomorrow need to make the most of the sun :cool:
Offline toby2can
« Reply #8 on: 14 July 2013, 22:14 »
any news on this one, ive have the same sort of problem. mine also happens when u put ur foot down from a stand still.
2002 Golf Gti AUM
Offline Perryd84
« Reply #9 on: 15 July 2013, 09:26 »
No fix yet  :sad:
Booked in for new rear bushes and to check all the mounts on Wednesday so will slam my brakes on couple times afterwards and report back :grin:
