Author Topic: Loud Bang when braking hard  (Read 3817 times)
Offline limmy
Re: Loud Bang when braking hard
« Reply #10 on: 15 July 2013, 13:40 »
are you optiing for cupra r rear axle bushes? Ive heard that they are a firmer ride
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #11 on: 15 July 2013, 13:58 »
Didn't think about that to be honest. Just want them replaced at the moment see if it sorts out the banging noise :huh:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline daddy5x
  • any time now milltek cat back remap
« Reply #12 on: 16 July 2013, 13:16 »
Lower engine mounting maybe :whistle:
standard gti turbo (aum     4 now
Offline xtetx
« Reply #13 on: 17 July 2013, 08:01 »
Do you have any clunking when full lock and going slow pal?
Offline Perryd84
« Reply #14 on: 17 July 2013, 08:56 »
Nah no clunking on full lock but hitting small bumps the back does bang, think that's the rear bushes. The actual original post sounds like its coming from the front though?!
Still baffled gonna get my mate to look over all the arms, suspension, mounts etc see what he can find.
Was meant to get the rear bushes done today but had to cancel.
Offline xtetx
« Reply #15 on: 17 July 2013, 12:25 »
no worries pal thought it was the front you were talking about :)
Offline Perryd84
« Reply #16 on: 06 August 2013, 08:25 »
Update:
So all bushes, arms, mounts and suspension is all fine!
Still no resolve on this mystery noise though?!
Wheel spun on a wet drain cover the other day and there was the loud bang again :cry: also another d**khead pulled out on a blind corner slammed on the brakes and there was the loud bang again?!!
Sounds like its from the front left of the car :huh: could it be the ABS locking up or something? But then wouldn't the dash light up if there was a problem?
So baffled what this is, no one seems to know :undecided:
Offline limmy
« Reply #17 on: 06 August 2013, 11:01 »
Has this only started since getting the lower wishbones replaced?
If so it could be due to them not torquing the bolts to the right specification... as mentioned they may look and feel tight but with the weight of the car it might be a different thing.
What lower wishbones did you buy. Some guys have opted for non-gen ones in the past the the bushes were like liquorice on their lowered cars.
ARB-wise when the bushes are worn, they only tend to make noise all the time or during uneven roads when the wheels move independantly.... not just went just braking.
Check front subframe bolts are tight - mine werent when i have some work done on my car which resulted in knocking
Usual suspects for knocking during braking are wishbone bushes so not really sure what else to suggest
Offline Perryd84
« Reply #18 on: 06 August 2013, 11:57 »
We did check all the bolts were tight but will double check them again to see if they are right.
Yeah the arms aren't genuine but I've used them before and they have been fine guess could have a dodgy one this time round.
I'm getting slightly obsessed with this now but I'm running out of things to check :huh:
Offline golfyste
  • Project track car
« Reply #19 on: 06 August 2013, 12:09 »
How did you check the top engine mounts?
I had a similar problem and I found when I removed the gearbox
Mount it felt ok moving it up and down but if I pushed it  left and right quite hard it actually shifted its position and replacing it solved the knocking issue.
