Author Topic: Finally Result Abs/handbrake light All Sorted  (Read 17080 times)
Offline vwwvgolf
Re: Handbrake Warning Light(Update)
« Reply #30 on: 22 April 2013, 15:20 »
ive said before on another post but,  send the ecu off to bba reman,  make an offer on ebay for 90 quid and they come pick your ecu up, fix it with a life time guarantee and send it back, then you know for sure its fixed and if anything else plays up you know its most likly to just be a sensor.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #31 on: 22 April 2013, 20:04 »
You can remove just the ecu so brake pipes can stay connected so no need to bleed,just bend them out the way a little
not worth it if a pipe snaps youve got to replace a brake line
It is worth it. You won't break the lines and its nort worth changing the whole pump unless the bolts holding the ecu are rusted and can't be undone. So your recommendation is going to cause the OP more work than is necessary.
Also who's to say, the whole new (second hand) unit won't be broken?
As I said earlier, most units you buy secondhand will probably have a fault on them anyway
Cheers for all your help/advise :afro: i shall remove the ecu i had a look earlier and the bolts aren't to bad shall have to see if fitting the secondhand unit hopefullly solves the fault,if not 'tshirt2k' will most likely be getting a pm  :grin: seems like your handy with fixing ecu faults :afro:
2000 Mkiv GTi 1.8T AGU
Offline tshirt2k
  • Been there...Done that...
« Reply #32 on: 22 April 2013, 22:08 »
You will need an E5 socket to remove the ecu.  :wink:
Mk3 ABF 16VT Megasquirt V3
Offline Callum_K
« Reply #33 on: 23 April 2013, 10:32 »
I will be PMing you in a few days too once I've got my hands on the correct socket, Halfords Pro tool kit only starts at E10!
  • "1.8T AGU"
« Reply #34 on: 23 April 2013, 21:59 »
Nice one :afro: well handy to know i'll pop into a local tool place and get one then  :wink:
** Just ordered one online be here friday  :grin:
« Last Edit: 23 April 2013, 22:15 by northeast_gti-t »
Offline matty james
« Reply #35 on: 24 April 2013, 22:12 »
ive only red ur post, none of the replies tho. ive had both ur probs when i had anmk3 8v, hand brake light stayed on when brake released, this too happened after getting new rear brake bits fitted , all it was was there was dirt on the hand brake sensor. If ur abs lite isnt lighting up at all its because its been on for agood length of time and the little bulb thing soldered in to the circuit board has burnt out due to been consantly on .
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
  • "1.8T AGU"
« Reply #36 on: 27 April 2013, 22:14 »
Replacement abs ecu not yet turned up  :angry: scanned it tonight and now the fault code is 01276 - ABS Hydraulic Pump (V64) 16-00 - Signal Outside Specifications  :laugh:
Offline xionsolaris
« Reply #37 on: 28 April 2013, 11:16 »
How much did u pay for abs module
  • "1.8T AGU"
« Reply #38 on: 28 April 2013, 22:21 »
decided as the replacement hasn't turned up that i ordered same part number pump/ecu last night from steven's dismantlers was £30 inc delivery  :wink: my units 1H2 614 117B ecu 3A0 907 379 if my original order turns up i'll be selling that  :grin:
Offline xionsolaris
« Reply #39 on: 29 April 2013, 06:48 »
Thts were i got my pump from its got 90 day guarantee but if you take the ecu off the bottom no guarantee
