Author Topic: Finally Result Abs/handbrake light All Sorted  (Read 17088 times)
Offline xionsolaris
Re: Handbrake Warning Light Still No Good!!
« Reply #50 on: 03 May 2013, 06:52 »
Yes agreed about clearing codes but in my case they just vanished most garages dont even realise the abs is not working on a mk3 if its not fixed by mot take the plug out of the back of the holder and put the face back onit most garages wont realise it but some can thts a last resort option
Offline northeast_gti-t
  • "1.8T AGU"
Re: Handbrake Warning Light now out but sensor fault rh
« Reply #51 on: 04 May 2013, 18:56 »
Well after sorting the ecu fault code,i opted to also change the rear lh sensor as that came up,ecu seems okay no fault shown and i have soldered my original unit and same result,fitted rear lh sensor a few mins ago and finally handbrake warning light is now out  :smiley: but shows rear rh sensor now  :rolleyes: will get a sensor fitted and fingers crossed this sorts the abs light.
2000 Mkiv GTi 1.8T AGU
VW BUSH
« Reply #52 on: 04 May 2013, 19:24 »
Recently did mine due to RH sensor showing constant fault, light did not go out with new sensor and ring.....
Fitted new LH sensor and ring, bingo
  • "1.8T AGU"
« Reply #53 on: 04 May 2013, 22:25 »
:afro: good to hear new rings on my rear hubs too will get a sensor on monday and get it fitted all four will be new then.
  • "1.8T AGU"
Re: Finally Result Abs/handbrake light All Sorted
« Reply #54 on: 06 May 2013, 10:58 »
Decided i would fit a new osr abs sensor and then all 4 have been replaced  :laugh: luckily i rang local eurocarparts this morning and they had one in stock  :smiley: been over and fitted it on the car fitted my new airbag/abs light unit (finally) and quick drive down the road and..............finally abs light went out :afro: checked and cleared old fault code and issue now resolved.
Offline madmanmart
« Reply #55 on: 06 May 2013, 12:34 »
A mk3 with working ABS  :shocked:
Your in a rare group............
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
VW BUSH
« Reply #56 on: 06 May 2013, 13:11 »
But not for very long :laugh:
Eicher sensors sold by GSF and Europarts are turd, they swell up and let in water.
You can make them last a little longer by relieving the hole they fit so they just drop in, but they eventually fail.
The left rear on mine was only 18 months old :shocked:
We will see how long mine lasts this time :grin:
Offline vr6D4v3
« Reply #57 on: 06 May 2013, 17:25 »
My abs is working fine.....
  • "1.8T AGU"
« Reply #58 on: 06 May 2013, 17:27 »
:grin: i am but for how long  :lipsrsealed:
  • "1.8T AGU"
« Reply #59 on: 06 May 2013, 17:35 »
