Author Topic: engine mayo  (Read 3800 times)
Offline GTi_James
engine mayo
« on: 02 April 2013, 09:34 »
morning all,
got an issue with my car making its own brand of mayo in large amounts, as in the dipstick has a nice thick coating when i check the levels.
any ideas? have run redex oil cleaner through the system and is due a service by the end of the month, should i wait until after the service to see if oil change makes a difference? i also use castrol GTX
any help would be appreciated fellas :)
Benny.banks
Re: engine mayo
« Reply #1 on: 02 April 2013, 10:07 »
Have you got water injection and a catch can? as my water injection causes my catch can to fill up quite quickly and when full, I gets the same thick creamy substance build up in the dipstick tube.
Offline xionsolaris
Re: engine mayo
« Reply #2 on: 02 April 2013, 10:21 »
Check oil cooler as water could be getting in the oil another thing are u only driving short distances as condensation from quick journeys can do this can u take pick of wht it looks like
Offline GTi_James
Re: engine mayo
« Reply #3 on: 02 April 2013, 10:31 »
....say'whaa? lol its a AUM, catch can is emptied once every 2months, thinking at service im gonna get them to change over the sump for the steel bottom conversion or should i just get the pick up cleaned and wait till i go lower for the sump conversion?
i had the pressure test done and no issues with HG, oil is somewhat black on the dipstick end so wondering if i should run some more redex oil cleaner through before the service at the end of the week so that its as clean as possible for when they do the oil change
i do short journeys but will be doing before and after picks this saturday as i am going south of london to pick up a goodey :)
analogue_rogue
Re: engine mayo
« Reply #4 on: 02 April 2013, 10:38 »
Short journies wouldnt cause the dipstick to cream up.. thats a LOT of water to do that!
Even with the pressure test i wouldnt trust it and wouldnt rule out HG.
Offline Nino
Re: engine mayo
« Reply #5 on: 02 April 2013, 10:39 »
Doing short journeys will cause this or worst case would be HG but as u said u have had this checked :)
Current - MK6 GTi Edition 35
Offline GTi_James
Re: engine mayo
« Reply #6 on: 02 April 2013, 10:55 »
the thing is though that all pipes are sealed, no moisture on the oil filler cap, maybe oil filter change and pick up pipe clean could clear this issue  :undecided:
Offline DubAndDubber
Re: engine mayo
« Reply #7 on: 02 April 2013, 11:02 »
Only other thing is a cracked head? Lost any power at all? Overheating?
Mk5 Golf Gti 06'
Offline Nino
Re: engine mayo
« Reply #8 on: 02 April 2013, 11:14 »
How many miles u av per day?
Re: engine mayo
« Reply #9 on: 02 April 2013, 11:22 »
Shirt journeys may cause condensation in the cap, but very rarely in the dipstick area
Mk5 Golf Gti 06'
