Author Topic: engine mayo  (Read 3826 times)
analogue_rogue
Re: engine mayo
« Reply #20 on: 02 April 2013, 17:32 »
Thats another good shout to be fair!
Offline GTi_James
Re: engine mayo
« Reply #21 on: 02 April 2013, 17:32 »
will do, may just change the standard silicone ones with the catch can to better ones tbh, its been nearly a year since they were done and may actually need a slean out tbh
Offline Nino
Re: engine mayo
« Reply #22 on: 02 April 2013, 18:45 »
Don't use engine flush on turbo engine very bad idea.
Current - MK6 GTi Edition 35
Offline GTi_James
Re: engine mayo
« Reply #23 on: 02 April 2013, 23:31 »
ok, nothing in compression tank, no smells, no smoke nothing, nudda, zilch, zero, nothing what so ever that has pointed to a head gasket so could this be down to short journeys and not much use over the last week?  :undecided:
i will be doing a massive journey this weekend so can up date whats happened etc
Re: engine mayo
« Reply #24 on: 02 April 2013, 23:44 »
Could be the oil cooler failed, drain and refill the oil then bypass it (join pipes together) and see if it comes back.
