Author Topic: engine mayo  (Read 3799 times)
Offline GTi_James
Re: engine mayo
« Reply #10 on: 02 April 2013, 11:24 »
averaging about 35-40 miles a day. no power loss, normal boost to 10 then drops 1-3 bars on cruise, has felt lumpy the last week but only infrequently, could possibly need a TB clean regarding that, getting all Temp and O2 sensors renewed.
 :undecided:
im at a lost, i know cold weather plays avoc with engine sludge and mine sits pretty i'd say 80% of the day
Offline GTi_James
Re: engine mayo
« Reply #11 on: 02 April 2013, 11:24 »
Shirt journeys may cause condensation in the cap, but very rarely in the dipstick area
i have noticed my dipstick has been pushed out a bit sometimes, probably poor fitting but it all came from vw  :huh:
anyone got the part number for the AUM sump and pick up? i want to know whether or not i'll be bent over forwards at my local even though i trust him, may have to do it myself
« Last Edit: 02 April 2013, 11:43 by GTi_James »
Offline Nino
Re: engine mayo
« Reply #12 on: 02 April 2013, 14:38 »
Well i went to VW and paid £63 for a oil pickup, sealent and sump plug, oil and oil filter
Current - MK6 GTi Edition 35
analogue_rogue
Re: engine mayo
« Reply #13 on: 02 April 2013, 15:46 »
if your dipstick is being pushed out there is a chance your sump is getting pressurised. Again possible head failure (remember cooling system is also pressurised) if you have a crack in the head or head gasket failure it would cause these symptoms. Short journeys dont cause dipstick mayo. only in the cap.
Get a cooling system pressure test done. Check to see if your coolant is leaking internally
Offline GTi_James
Re: engine mayo
« Reply #14 on: 02 April 2013, 17:12 »
but i havent had to fill up coolant since major service last year august with VW and have covered more than 10000 miles since then  :undecided:
as i understand heads arent too bad to do and may get a mate to help if it gets a bit nitty gritty though this could also be a chance for an AGU conversion maybe so that i can push more power through the Ko3s and not worry about the flimsy AUM issues  :undecided:
hopefully its just the short journeys and cold weather, i'll be checking the issue again saturday as i have a major trip, and yes i have break down service and a place it can be stored
analogue_rogue
Re: engine mayo
« Reply #15 on: 02 April 2013, 17:15 »
none at all?
Offline GTi_James
Re: engine mayo
« Reply #16 on: 02 April 2013, 17:20 »
pretty much  :undecided:
could be mistaken but i can remember undoing that lid, i'll have to check now  :rolleyes: if not then its a pretty good excuse for and AGU conversion with Ko3s, the engine is sound though and no smoke what so ever and only that annoying ticking from the carbon canister
analogue_rogue
Re: engine mayo
« Reply #17 on: 02 April 2013, 17:25 »
engine flush and mark levels on expansion tanks and dipstick. then test for a few weeks and see what happens?
Offline GTi_James
Re: engine mayo
« Reply #18 on: 02 April 2013, 17:27 »
didnt think flushing was good for the engine though? i did have the old school pressure test done about early jan, i just found a reciept, came back clear, no discolouration at all
Offline james2
  • No scammers please.
Re: engine mayo
« Reply #19 on: 02 April 2013, 17:29 »
i would check your engine breathers see if anythings slightly blocked.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
