Author Topic: Boost Gauge Confusion?! Need advise!!  (Read 4045 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« on: 28 February 2013, 09:32 »
I'm about to install a boost gauge and I have read all the guides and looks easy enough............but.........pardon my ignorance :embarrassed: , why does it T into the fuel pressure regulator? What does that have to do with boost pressure? Wouldn't it make more sense to go on the vac pipe on the DV??
I ain't no mechanic so I'm probably well wrong but wouldn't that mean you could stick a boost gauge on any old car not just a turbo? :huh:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline GTi_James
Re: Boost Gauge Confusion?! Need advise!!
« Reply #1 on: 28 February 2013, 09:58 »
 :huh: just put it into the pipe going into the top of DV matey
Offline Perryd84
« Reply #2 on: 28 February 2013, 10:02 »
That was my first plan but then after reading tons of guides they all say tap into the fuel pressure regulator so now I'm confused?!?!
« Reply #3 on: 28 February 2013, 10:30 »
That is correct, just tee off that pipe as required.
Offline rio_gti
« Reply #4 on: 28 February 2013, 10:47 »
Both of them are vacuum pipes and both go to the inlet manifold so they both have the same pressure in them!! Just if you use the fpr vacuum and you have a leak on it you can end up running lean  :lipsrsealed:
Also off the dv you need shorter pipe!!!
Offline Perryd84
« Reply #5 on: 28 February 2013, 11:03 »
So would you recommend running off the DV then?
Offline rio_gti
« Reply #6 on: 28 February 2013, 11:48 »
Personal preference really, I had it there cos it ran under the bulkhead hidden
Offline Perryd84
« Reply #7 on: 28 February 2013, 11:59 »
Sweet! Think I will just tap off the DV then and maybe move it at a later date. Cheers!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 28 February 2013, 18:24 »
If you have a leak anywhere you plumb the boost gauge into you will run like a bag of poo, not just at the FPR
Offline Perryd84
« Reply #9 on: 01 March 2013, 13:33 »
Cheers for advice! One more thing, i have a smoked face boost gauge so it only shows with the backlight on. Can i still tap into the dimmer light or will it only work when the lights are on?
