Author Topic: Boost Gauge Confusion?! Need advise!!  (Read 4046 times)
Offline cullygti
Re: Boost Gauge Confusion?! Need advise!!
« Reply #10 on: 01 March 2013, 14:00 »
Cheers for advice! One more thing, i have a smoked face boost gauge so it only shows with the backlight on. Can i still tap into the dimmer light or will it only work when the lights are on?
yes mate you can tap into that ...thats what i have done and yes again will only worjk when lights are on  :wink:
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #11 on: 01 March 2013, 14:09 »
Hmm.. Need a line which comes on with the ignition?! Any ideas other than the radio? Wires a bit short so need something near the a pillar?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline rio_gti
« Reply #12 on: 01 March 2013, 14:30 »
Or extend the wires  :lipsrsealed:
Only thing not doing it on dimmer is if its too bright it might annoy you at night
Offline beppe2672
« Reply #13 on: 01 March 2013, 14:35 »
If you go behind your fuse panel, there should be a few thick yellow/black wires, they're ignition switched. Ive got my sat nav tucked behind the dash and tapped into them so there's no wires hanging about.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 01 March 2013, 15:21 »
one of the wires to the headlight switch is ignition live, can't remember the colour though
Offline Perryd84
« Reply #15 on: 01 March 2013, 15:53 »
Well I've been trying to do this for the last half hour and have failed massively  :embarrassed: !!! For the life of me i can't find how to get the boost pipe into the cabin without drilling a hole through?! I know all the guides say put it through this or that gromit but i can see f**k all that looks gromitish?!? Tried following a few electric cables but no luck just seems to get stuck somewhere! :angry:
Fuming, i hate it when i cant do something  :angry: reckon a trip to the garage is my only way :embarrassed:
Offline rio_gti
« Reply #16 on: 01 March 2013, 16:33 »
Where abouts are you??
I ended up runnin it down where the bonnet pull is
Offline Perryd84
« Reply #17 on: 01 March 2013, 16:55 »
I've given up for today! In in beckenham area (if that's what you meant?)
I looked at the bonnet pull line but again once it goes out of site just gets stuck?!
Done bit of research this grommet that loads put it through is only free if the car is not cable throttle which mine is so theres no free grommet to go through.
The drill keeps coming to mind  :grin:
Offline mar_k
« Reply #18 on: 01 March 2013, 17:53 »
I have a 3 wire boost gauge but found I only needed to use 2 wires,
One was the earth and the other onto the light switch,
It dims as it should and works as it should, I cut the other wire off
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 01 March 2013, 21:18 »
the other wire you cut off dims the LED when you turn the lights on
