Author Topic: devils own wmi progressive controller (voltage).  (Read 3866 times)
Offline wotavudunn
« on: 17 December 2012, 00:35 »
does anyone have one of these kits fitted to the AGU 1.8T? as i can only hook the controller up to my MAF. the green wire on the controller should attach to a wire on the MAF that at idle should read between 0.8-1.2 volts and with the ignition on without the car started it should read between 1.8 - 2.8 volts. now ive tested all the wires with a volt meter and NONE read this.
i have 4 wires on the plug to my MAF
brown/red  -0.01 volts
brown/blue -0.01 volts
blue/yellow 13.41 volts
blue 0.05
can anyone help? what am i doing wrong?
Offline mcgee9t2
Re: devils own wmi progressive controller (voltage).
« Reply #1 on: 17 December 2012, 07:37 »
Dodgy maf? common thing to go on a mk4
Offline wotavudunn
« Reply #2 on: 17 December 2012, 08:47 »
lol its not the MAF im testing. its the 4 pin plug that goes onto the MAF.
Offline mcgee9t2
« Reply #3 on: 17 December 2012, 12:24 »
ah sorry yeah , was early :rolleyes: :laugh:
Offline wotavudunn
« Reply #4 on: 17 December 2012, 13:59 »
so no one has this controller?
Offline wotavudunn
« Reply #5 on: 17 December 2012, 21:05 »
anyone?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 17 December 2012, 21:24 »
the green wire is definitely the one you need to hook up to. If the green light is on on the controller all the time it means it's sensing full boost so it's got to be the wrong wire
Offline wotavudunn
« Reply #7 on: 17 December 2012, 21:55 »
i just need to no what wire on the maf plug to wire it to.
Offline Chris.
« Reply #8 on: 17 December 2012, 23:04 »
Why you connecting your WMI to your maf?
Click For Build Thread
Offline shaft69
« Reply #9 on: 17 December 2012, 23:43 »
blue 0.05
Doesn't sound right that will have a look at mine tomorrow and tell you pin number mine was connected to should be same.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
