Author Topic: devils own wmi progressive controller (voltage).  (Read 3864 times)
Offline wotavudunn
Re: devils own wmi progressive controller (voltage).
« Reply #10 on: 18 December 2012, 10:30 »
Why you connecting your WMI to your maf?
lol im not connecting the nozzle to the maf. im just connecting the controller to the maf because i dont have a map sensor as i have a prehistoric AGU lol
Offline wotavudunn
« Reply #11 on: 18 December 2012, 10:31 »
and cheers shaft69 that would be a massive help.
Offline Chris.
« Reply #12 on: 18 December 2012, 11:21 »
Thought they was boost controlled.
Click For Build Thread
Offline wotavudunn
« Reply #13 on: 18 December 2012, 11:30 »
yea thats the old fashioned way.
Offline wotavudunn
« Reply #14 on: 18 December 2012, 18:54 »
n e one?
Offline Chris.
« Reply #15 on: 18 December 2012, 22:32 »
surely your controller would need to know what readings/formulas the ECU uses to created boost.   AGU uses load to calculate boost required/defined in ECU.
Surely there is a boost pipe to connect to controller as every car would be different settings?  Got a link to the instruction book?
Offline wotavudunn
« Reply #16 on: 18 December 2012, 22:57 »
this is the link to the contoller
http://www.methanol-injection.co.uk/product_info.php?products_id=136
Offline Chris.
« Reply #17 on: 18 December 2012, 23:37 »
Quote
This controller has a built in 4.5Bar MAP sensor.
There you go....wire it up to boost feed (guessing its from under inlet) and it should work?
Offline wotavudunn
« Reply #18 on: 19 December 2012, 00:39 »
how would i do this? as there is only 5 wires on the controller. heres the diagram. sorry if the pics are crap.
Offline wotavudunn
« Reply #19 on: 19 December 2012, 15:47 »
just found out water meth controllers cannot be fitted to AGU 1.8T's. gutted £350 down the pan.
