Author Topic: devils own wmi progressive controller (voltage).  (Read 3869 times)
Offline wotavudunn
Re: devils own wmi progressive controller (voltage).
« Reply #20 on: 19 December 2012, 20:15 »
Quote
This controller has a built in 4.5Bar MAP sensor.
There you go....wire it up to boost feed (guessing its from under inlet) and it should work?
there is no connection for boost feed as its voltage controlled and not boost.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 19 December 2012, 20:56 »
The boost one can, might be worth seeing if someone wants to swap
Offline wotavudunn
« Reply #22 on: 19 December 2012, 20:59 »
contacted devils own with no reply, they were the ones that recommended the voltage controller. which controller do you have wazzer?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #23 on: 19 December 2012, 21:08 »
Mine is the boost controlled version, I connected mine up off the boost gauge
Offline wotavudunn
« Reply #24 on: 19 December 2012, 22:23 »
the very nice man at devils own uk has agreed to swap it for me.......RESULT. :wink:
