Author Topic: K03 and k03s indentification marks  (Read 2850 times)
Offline mar_k
« on: 05 August 2012, 21:15 »
When looking at the plate on the turbo I couldnt see any clear markings to show weather it was
either of the above.
Where would it be and how would it have been stamped?
Offline richw911
Re: K03 and k03s indentification marks
« Reply #1 on: 05 August 2012, 21:20 »
http://www.golfgtiforum.co.uk/index.php?topic=93942.0
"KO3s turbo numbers:
KO3-052, 053,058 or (K03/82 from a Polo GTI) For k03s
If you look into the inlet, the ko3 has 12 fins, the ko3s has 8."
Offline mar_k
« Reply #2 on: 05 August 2012, 21:25 »
Cheers rich, So do all K03s turbos look the same with that larger bit at the top?
Offline richw911
« Reply #3 on: 05 August 2012, 21:32 »
No that is a silencer which were fitted to AUQ engines IIRC, AUM and others look the same as k03 - its the fins you want to check out  :smiley:
Offline mar_k
« Reply #4 on: 05 August 2012, 21:35 »
Was getting worried, My mates is AUM and is the same as the bottom one,
Pretty certain there is 8 fins, certainly dont recall the fins being as close together as the K03 pic.
I am a little concernd about the way the car has been treated in the past, There wasnt even a gasket between the wastegate and manifold
Offline jamie1989
« Reply #5 on: 05 August 2012, 21:47 »
There shudnt be a gasket there lol
Dont you mean the manifold to turbo?
Or block to manifold?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline mar_k
« Reply #6 on: 05 August 2012, 22:01 »
Turbo to manifold, However imo its not really the turbo is it? Its the exhaust housing
Offline golfyste
  • Project track car
« Reply #7 on: 06 August 2012, 06:48 »
You mean the turbo where the wastegate is located to manifold?
As that is the hotside of the turbo
Offline mar_k
« Reply #8 on: 06 August 2012, 10:20 »
yes, there wasnt a gasket there at all
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 06 August 2012, 10:25 »
there should only be a gasket on the turbo to manifold join and the exhaust housing to downpipe join
