Author Topic: K03 and k03s indentification marks  (Read 2851 times)
Offline mar_k
Re: K03 and k03s indentification marks
« Reply #10 on: 06 August 2012, 10:39 »
there should only be a gasket on the turbo to manifold join and the exhaust housing to downpipe join
The downpipe one was there but not turbo to manifold.
triangle shaped with 3 holes
Offline golfyste
  • Project track car
« Reply #11 on: 06 August 2012, 10:43 »
Hmmm you mentioned being concerned about how it has been treat.
What else is making you worried?
Tbh not replacing the gasket is just daft and bone idle would make sure you give ths rest of the caeca good check over
Offline jamie1989
« Reply #12 on: 06 August 2012, 10:49 »
I bet it was blowing a little.
I agree its bone idle now to replace it I know from expierence its a potch to get that gasket lined up but I cheated and used a little silicone sealant lol
I wouldnt be worried about the engine if it sounds good an pulls well the 1.8t's are pretty much bullet proof aslong as the oil changes have been regular an serviced well.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline mar_k
« Reply #13 on: 06 August 2012, 10:51 »
We have fitted a gasket now,
The previous owner had lied about a few things, like having a new clutch fitted.
Its my mates fault as he didnt check through the paper work properly.
There were a few badly repaired things on the car which have now been sorted.
Its actualy a really nice car but seems to have been neglected abit.
There was also a cheap cone filter on there which had gone rusty on the top and bottom metal parts.
Now replaced for a standard airbox, just waiting for the piper x panel filter to turn up
One good thing though, The intercooler is a forge smic. Not sure what its good for but its deffinately bigger than the standard one
Offline mar_k
« Reply #14 on: 06 August 2012, 10:54 »
Jamie, when he 1st brought it round to me I told him there was a blow somewhere as I could hear it.
At least its done now, Yes it was abit of a pain but since we had the turbo off to sort out the studs for the downpipe it was no bother.
