Author Topic: Where can I buy a THS FMIC or alternative  (Read 18032 times)
Offline ReDBull
Re: Where can I buy a THS FMIC or alternative
« Reply #30 on: 02 August 2012, 17:50 »
So you get the idea of what I'm rambling on about :laugh:  I have shamelessly stolen some photos from various threads. Sorry if I've stolen your picks!
This is the ASN way of doing it. 90 deg from the FMIC and 76 hosing which is reduced as late as possible.
Then the forge/SCN way of doing it with 45 deg from FMIC again reduced as late as possible but this time with hard pipes.
Then reduced from the FMIC with 45deg piping and 63mm piping the rest of the way
Then hard piping reduced from 76mm to 63 mm straight from the FMIC.
Like I said lots of different ways of doing the same thing! Have a look through the threads and see which way is best for you!
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #31 on: 02 August 2012, 17:59 »
Some do.
My mates PD130 has them.
aftermarket, they were never released with them from the factory :nerd:
Offline DunnDeal12
  • Limited
« Reply #32 on: 02 August 2012, 18:01 »
Some do.
like wazzer says aftermarket :tongue: :smug:
Offline dom
  • Back in a Mk4
« Reply #33 on: 02 August 2012, 19:32 »
Have you got any pics of the above setup on a Mk4? I'm tempted by it but want the pipework discreet so I'd want to keep my grills in the bumper.
Offline Dalo Harkin
« Reply #34 on: 02 August 2012, 20:56 »
my parts are on the way  :wink:
Offline dom
  • Back in a Mk4
« Reply #35 on: 02 August 2012, 20:59 »
You doing it the way shown above?
Offline jamie1989
« Reply #36 on: 02 August 2012, 21:00 »
woww never knew that they were after market.
You geeks  :grin:
Those intercoolers look awsome too
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Dalo Harkin
« Reply #37 on: 02 August 2012, 21:02 »
Im going to trial it different ways and see whats the best fit, I have ordered a K04 charge pipe and an LCR inlet manifold to make it easier though
Offline ReDBull
« Reply #38 on: 02 August 2012, 21:06 »
Good lad!
I recived my 45 deg 76mm to 63mm reducer earlier. You can put your fist in the 76mm end, it's car porn! :laugh: :evil: :cool:
Offline mar_k
« Reply #39 on: 02 August 2012, 21:10 »
So would an intercooler with 3" inlet/outlets be ok for around 250bhp or would it be overkill?
Would a smaller intercooler with 2.25" inlet/outlet be better suited?
« Last Edit: 02 August 2012, 21:15 by mar_k »
