Author Topic: Where can I buy a THS FMIC or alternative  (Read 18013 times)
Offline ReDBull
Re: Where can I buy a THS FMIC or alternative
« Reply #20 on: 02 August 2012, 14:55 »
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline jamie1989
« Reply #21 on: 02 August 2012, 15:22 »
Custom pipework?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline DunnDeal12
  • Limited
« Reply #22 on: 02 August 2012, 16:03 »
Custom pipework?
nope all you need is this
Intercooler specs are 600 x 300 x 76mm http://www.ebay.co.uk/itm/FMIC-FFRONT-MOUNT-TURBO-INTERCOOLER-TYPE-B-600x300x76MM-/310228624694?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483b112536#ht_674wt_1163
2 x 90 degree 76mm hard pipes with beaded ends. http://www.ebay.co.uk/itm/90-Degree-Alloy-Aluminium-Pipe-Bend-Elbow-Intercooler-Pipework-Air-Intake-/160658691823?pt=LH_DefaultDomain_3&var=&hash=item25680116ef#ht_1832wt_1163
2 x 90 degree 76mm silicone elbows in your choice of colour - these will need adjusting to length during fitting. http://www.ebay.co.uk/itm/90-Degree-Silicone-Elbow-Bend-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Car-/330650756290?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item4cfc5224c2#ht_1102wt_905
2 x 90 degree 76 - 63mm reducing silicone elbows in your choice of colour. http://www.ebay.co.uk/itm/90-Degree-Reducers-Silicone-Elbow-Bend-Hose-Silicone-Rubber-Coolant-Rad-Pipe-/270865046133?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3f10d09a75#ht_1102wt_905
2 x 63mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
2 x 76mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
1 x 76mm 250mm length of straight silicone hose in your choice of colour. This needs to be cut into 2 lengths of 125mm to go on the end tanks of the cooler. http://www.ebay.co.uk/itm/1-Meter-Straight-Silicone-Hose-Size-Colour-Choice-Roose-Motorsport-/251051638993?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3a73d800d1#ht_2300wt_1163
10 x 70 - 90mm jubilee clips http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
2 x 50 - 70mm jubilee clips. http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
« Last Edit: 02 August 2012, 16:16 by DunnDeal12 »
Offline jamie1989
« Reply #23 on: 02 August 2012, 16:04 »
Awww I cant bloody use ebay on works computer  :sad:
Will check later lol
Offline DunnDeal12
  • Limited
« Reply #24 on: 02 August 2012, 16:05 »
that better mate?
Offline jamie1989
« Reply #25 on: 02 August 2012, 16:14 »
haha much better for me although I was being nosey thats all  :evil:
Offline DunnDeal12
  • Limited
« Reply #26 on: 02 August 2012, 16:17 »
cheeky lol also links provided
Offline ReDBull
« Reply #27 on: 02 August 2012, 17:22 »
There is more than one way of doing it. The ASN boy use 90deg piping straight from the FMIC. On SCN they tend to use 45deg piping from the FMIC as forge do in there BIG race FMIC. You can also either use 76mm piping all the way to the map pipe and charge pipe then step it down. Or as I am use a 45deg 76mm to 63mm reducer from the FMIC and the 63 mm piping the rest of the way.
Here's the forge fitting instructions from forge http://www.forgemotorsport.co.uk/media/FMINTLCR.pdf
Going down to 63mm gives you much more space to refit the bumper cover and possibly fog lights.
Have a good read through the links posted and see which way you want to go. I would highly recommend reading the links!!!! :smiley:
Offline DunnDeal12
  • Limited
« Reply #28 on: 02 August 2012, 17:36 »
golfs don't have lower fog lights!
Offline jamie1989
« Reply #29 on: 02 August 2012, 17:37 »
Some do.
My mates PD130 has them.
