Author Topic: Where can I buy a THS FMIC or alternative  (Read 18014 times)
Offline golfyste
  • Project track car
Re: Where can I buy a THS FMIC or alternative
« Reply #90 on: 07 August 2012, 07:45 »
I think prawnys' whole right up over the last two pages shoul be put on a thread for "fmic choices and how to"
And stickied!
Good effort pal  :cool:
Offline dom
  • Back in a Mk4
« Reply #91 on: 07 August 2012, 13:40 »
And stickied!
Agreed, can a mod take his posts and put them into a separate thread to be stickied? It would save the gazillion threads that seem to be appearing about fmic's at the moment. :grin:
Offline richw911
« Reply #92 on: 07 August 2012, 15:07 »
Done  :cool:
Offline ReDBull
« Reply #93 on: 07 August 2012, 20:36 »
Thanks Nick for comeing over and filling the huge holes in my knowledge :grin:
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline rio_gti
« Reply #94 on: 08 August 2012, 14:10 »
so what do you do about the map sensor?
Offline Dalo Harkin
« Reply #95 on: 08 August 2012, 14:34 »
+1 is it the ONLY option to use the forge tube with it in or get a boss welded on  :undecided:
Offline rio_gti
« Reply #96 on: 08 August 2012, 15:18 »
Or even attaching the boss to the silicone hosing maybe
Offline ReDBull
« Reply #97 on: 08 August 2012, 18:25 »
For those of us with the throttle body on the passenger side there's two options.
Option one connect to the plastic map pipe
Option two add the forge alloy map pipe
For those of you with the throttle body on the wrong/right side sorry it's all Chinese to me  :kiss:
Offline Prawny
  • R-tech power!!!
« Reply #98 on: 09 August 2012, 08:41 »
If you have an LCR, just retain the stock MAP sensor plastic pipe as most people do.
if you have anything else, then where my pipe run uses a 63mm 100mm alloy joiner, just replace that with the forge map pipe under the headlight. Works a treat on the ones I've done.
Offline ReDBull
« Reply #99 on: 09 August 2012, 18:44 »
This has arrived
Just need the correct pipe work to arrive and the time to fit it now.
