Author Topic: Where can I buy a THS FMIC or alternative  (Read 18029 times)
Offline ReDBull
Re: Where can I buy a THS FMIC or alternative
« Reply #81 on: 06 August 2012, 14:06 »
parts extra that'll need to be sent back due to the difference in peoples opinions of what is/isnt needed.
the benefit for me doing it the S3/Cupra way is that its less pipework (completely removes the pancake pipe work etc) and you can see on the images that it shouldnt be that hard to do (famous last words  :grin: )
all my parts should be here by the end of the week and I have given myself Sat and Sun to fit the bad boy  :evil:
missus ST TDCI is in for MOT though so may need some bits for that doing, if I have to pull an all nighter to fit the FMIC I will  :grin:
Great knew think a like. Not just the Wellycooler but ST TDCI for the wife. How ever we just sold it!
It's great that there's so many different ways to do it. Can't wait for mine to arrive however half the silicone pipe work has turned up the wrong colour arse!
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline azzsmith
« Reply #82 on: 06 August 2012, 15:01 »
Does anyone know what diameter silicone I will need to go to an agu throttle body?
black magic agu 240bhp
Offline ReDBull
« Reply #83 on: 06 August 2012, 15:30 »
Don't no for sure but I'd say 63mm which is the magic number on a good flowing FMIC on these engines check out the relentless page on facebook there's also info on there.
« Last Edit: 06 August 2012, 15:32 by bullyboy »
Offline azzsmith
« Reply #84 on: 06 August 2012, 16:07 »
cheers fella, will do
Offline azzsmith
« Reply #85 on: 06 August 2012, 16:19 »
I'v seen some people use silicone on the 90/45 degree bends and some people use alloy?  :huh:
Whats the difference and does it matter what you use?
Offline Dalo Harkin
« Reply #86 on: 06 August 2012, 17:10 »
Well other than the obvious that the alloy wont be as flexible, you obviously need to have alloy each side of the silicone to tighten it onto
other than that I think you can use what you like / prefer, I have opted for as much alloy as I can and using small pieces of silicone to join them.
Cant wait, some bits should be there today  :smiley:
Offline rio_gti
« Reply #87 on: 06 August 2012, 22:07 »
So doin it prawny's way is pretty much the same pipe length as doin it the welly way, so there would be no difference in performance wise?
Is it just how it looks that's different? Also easier as our inlets are originally this way round
Surely it should be a bit better as the charge pipe isn't above the hot exhaust manifold??
What are the cons of doing it like this???
Offline paultownsend
« Reply #88 on: 06 August 2012, 22:19 »
Prawn. You are THE MAN
So the only real restriction here is the 51mm outlet on the turbo?
I can see you've moved the dv to the cold side. Is it just a take off for the n75 you have to add?
« Last Edit: 06 August 2012, 23:30 by paultownsend »
Offline Prawny
  • R-tech power!!!
« Reply #89 on: 07 August 2012, 06:48 »
yea, after the turbo outlet it goes straight to 63mm the whole way, apart from the entry and exit from the cooler. Mine works fantastically well!
I did have a cold side kit at the time of fitting yes, although the DV has since been moved back to the first alloy charge pipe after the turbo, Niki prefered it this way.
Wellys setup, and parts list, is his way of installing it on an S3 / LCR (silly left handed inlet), and the lower section is much more visable.
Mine works for a ko3 / ko4 setup on a mk4 golf / LC / A3 running a right handed inlet.
Only change between ko3 and ko4 fitment is the first pipe, ko3 fitment uses a silicon 51-63 straight expansion onto an alloy 90, then a coupler onto the 45 and down, ko4 fitment just uses a 51-63 90 reducer straight off the turbo.
