Author Topic: Where can I buy a THS FMIC or alternative  (Read 18044 times)
Offline ReDBull
Re: Where can I buy a THS FMIC or alternative
« Reply #60 on: 04 August 2012, 14:04 »
I got my info from these links, lots of good info. I'm also fitting an oil cooler at the same time
http://www.seatcupra.net/forums/showthread.php?t=350372
http://www.seatcupra.net/forums/showthread.php?t=353162#
http://www.forgemotorsport.co.uk/media/FMINTLCR.pdf
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/150098-wellycooler-fitting.html
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/75425-ah-fab-ebay-forge-s3-fmic-image-heavy.html
Lots of different ways of doing the pipe work but don't forget my inlet manifold is on the other side to yours! Have a look at the photos I postedpin page 4 and you'll see what I mean. There is eBay links on the above threads to Mr silicon for ASH (sister company to forge) silicone hoses and alloy pipe work. I've read the above threads quite a few times so I know how to fit it and which way I want to go with the pipe work. But I'm not sure exactly which pipe work you'll need sorry. You could always sign up to Audi Sport net. There a good bunch and will help you out. Hope that helps.
« Last Edit: 04 August 2012, 14:08 by bullyboy »
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline azzsmith
« Reply #61 on: 04 August 2012, 18:13 »
Thanks a lot for your help mate, really appreciate it  :smiley:
black magic agu 240bhp
Offline ReDBull
« Reply #62 on: 05 August 2012, 11:11 »
How come everyone seems to be buying FMIC on here at the moment :laugh:?
Offline azzsmith
« Reply #63 on: 05 August 2012, 11:18 »
Must be a virus, we'v all caught it lol  :laugh:
Offline Chris.
« Reply #64 on: 05 August 2012, 12:22 »
How much do the pipes stick out on a mk4 bumper tho?
3" is a lot of pipework for a k03s to fill up, especially the core.  Bet you see a nice increase in lag.
Click For Build Thread
Offline Dalo Harkin
« Reply #65 on: 05 August 2012, 19:12 »
I have reduced to 63mm from the IC inlet/outlet exactly for this reason and to hopefully give more room in fitting and less cutting
Offline Dalo Harkin
« Reply #66 on: 05 August 2012, 19:44 »
also for people reading this remember that the shopping list for parts are different depending on the car and which route you want to take on the piping.
I am going to have a K04 charge pipe and an LCR inlet manifold to reduce the amount of piping needed
I have ordered the parts listed as being needed here post 19
BUt that is the LCR way (throttle body on the passenger side and not drivers and a K04 charge pipe)
Offline ReDBull
« Reply #67 on: 05 August 2012, 19:45 »
I've asked about the lag to but the size is supposed to incease the flow reducing pressure across the core, and lag is not supposed to be a problem. Only a 5 psi drop Oxford the core was loved by one user. How much psi do you run on a stage 2 K03?
As above I'm going to be using 76/63mm 45 deg reducers from the FMIC. On my standard LCR I'm peaking at 14psi and holding 12. I've not heard any negative response to this cooler set up.
Offline Dalo Harkin
« Reply #68 on: 06 August 2012, 07:46 »
UPDATE - after spending a long time reviewing all this I am doing this exact route (pipework is also listed) BUT with 63mm piping
It amounts to roughly £240 including the IC, all pipework and clamps and P&P  :wink:
Offline azzsmith
« Reply #69 on: 06 August 2012, 09:00 »
The link doesn't mention the pipe lengths... is it just a case of measuring up what lengths are needed?  :huh:
