Author Topic: new engine!  (Read 2867 times)
Offline danyo
Re: new engine!
« Reply #10 on: 30 June 2012, 12:57 »
a new turbo wouldn't have killed your gearbox
you recon it wasn't fitted properly to the new engine then? am i right in saying you shouldnt need to top up the gearbox oil, cus apparently it lasts forever? or is that bullsh*t?
Offline DunnDeal12
  • Limited
Re: new engine!
« Reply #11 on: 30 June 2012, 13:03 »
I had a mate who knew someone dat had a gearbox problem after dere air filter was changed so mite wanna check ur air filter of u have a whine
funnest thing ive heard all  day.
Offline danyo
Re: new engine!
« Reply #12 on: 30 June 2012, 13:15 »
was thinking the same  :laugh:
Offline mcgee9t2
Re: new engine!
« Reply #13 on: 30 June 2012, 13:19 »
it must ov been al dat extra powa frm da filta
i think it was just coincidence (sp?) that his gear box went after he fitted a filter
Offline leigh_harty
  • Audi AGU
Re: new engine!
« Reply #14 on: 30 June 2012, 14:11 »
gearbox on its last legs.. raggin it round with a new turbo finished it off?
Dont lose your dinosaur!
Offline dan2252
Re: new engine!
« Reply #15 on: 30 June 2012, 14:21 »
or maybe just you were unlucky and gear box was gonna go anyways.. a new turbo isnt gonna kill your box, plenty of people go put 300 bhp through a mk4 box and im sure theres would go straight away if yours did. just check gear oil, remove the 17 mm allen key out of the front of the box and if oil runs out its fine. if loads of oil runs out quick its over full so let it go till its slowly running out the box, check the oil in the box for bits of metal, but like a guy said earlyer on here not your cambelt over tight is it? your mate know owt about cars?,
MK4 golf 1.8 turbo agu :)
Re: new engine!
« Reply #16 on: 30 June 2012, 14:34 »
Check and make sure the gearbox has oil in it first.
Offline dan2252
Re: new engine!
« Reply #17 on: 30 June 2012, 14:43 »
check the oil like the guy above said. coz correct me if im wrong but when oil levels are low on boxes dont they normaly kill the 5th gear first? because its first one to have no oil around it because its at the end of the box?
Offline danyo
Re: new engine!
« Reply #18 on: 30 June 2012, 17:06 »
the box was fine before the new engine and turbo, but then im not mechanic to say it was on its way out anyway! and no havent been ragging it, wearing the new turbo in first :)
i will check the oil in the box and see what state it is in!
whats currently the cheapest option? get it repaired? new one? spent nearly 2k last week getting it back on the road so money is a bit tight at the moment!
Re: new engine!
« Reply #19 on: 30 June 2012, 21:45 »
Makes you wonder if they have put something together wrong  :undecided:
Try and find a secondhand gearbox.
