Author Topic: new engine!  (Read 2865 times)
Offline danyo
new engine!
« on: 29 June 2012, 23:02 »
after a few weeks off the road, i finally found a donor 1.8t 20v auq engine!
got it back yesterday and everything seemed fine.....
driving back from work today, sounded like someone had fitted a supercharger to my car!! it's the exact noise 1 makes! any suggestions on what it could be?
also in 5th / 6th gear the noise gets alot louder and the gears sort of grind if i drop it down a gear!?
Re: new engine!
« Reply #1 on: 30 June 2012, 00:04 »
The whine could be cam belt too tight or maybe they have not filled the gearbox with oil.
Offline jonrandom
Re: new engine!
« Reply #2 on: 30 June 2012, 03:12 »
would not b good!
Offline danyo
Re: new engine!
« Reply #3 on: 30 June 2012, 11:14 »
just got it checked! apparently its the gearbox... anyone know of anywhere that do decent recon ones?
Offline DunnDeal12
  • Limited
Re: new engine!
« Reply #4 on: 30 June 2012, 11:17 »
is yours 5 speed or 6 speed?
if its a 5 speed then i recommend upgrading it to a 6 speed as there stronger.
Offline danyo
Re: new engine!
« Reply #5 on: 30 June 2012, 11:21 »
its a 6 speed and was told there pretty weak! just had a new turbo put on and apparently that has caused the problem?
Offline DunnDeal12
  • Limited
Re: new engine!
« Reply #6 on: 30 June 2012, 12:03 »
new turbo cause gearbox problems that's a new one, didn't go kwik fit did you?
and the 6-speed are the better/stronger box.
Offline danyo
Re: new engine!
« Reply #7 on: 30 June 2012, 12:09 »
that's what i was thinking! no i went to a mate of mine, but he's not the sort of person to give me any bull!
could it be something to do with bolting the gearbox onto the new engine i have had? maybe they guy that fitted did something wrong?
Offline moby
Re: new engine!
« Reply #8 on: 30 June 2012, 12:42 »
I had a mate who knew someone dat had a gearbox problem after dere air filter was changed so mite wanna check ur air filter of u have a whine
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: new engine!
« Reply #9 on: 30 June 2012, 12:49 »
a new turbo wouldn't have killed your gearbox
