Author Topic: forge split r fitted in recirc mode but getting turbo flutter from air filter  (Read 12195 times)
Offline AD1.8T
I brought mine from awesome and all i got was the 007p itself no springs service kit not even wrapped well it was just in a forge box with no packaging if i emailed forge would they send one out ?
Offline rockmonkey69
Spring kit is sold separately from Forge, it does not come with the 007p
Offline golf-sib
  • Турботазик
Try, see what they come back with, I have found there customer service to be exceptional, I doubt they will send out the service kit as they charge for these now.
If you generally never got the spring you desired they will typically send you one free of charge, just don't abuse there generosity.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I would have thought you should get at least one spring in there  :undecided:
Offline Dalo Harkin
you get te green one iirc unless you state otherwise and then they will change for you before shipping
Offline GTIcheeseman
Right I serviced it with red grease. Basically it does work but only really at boost at low poddle it gets turbo flutter I'm.gettin rather confused
Offline golf-sib
  • Турботазик
You scanned for any codes?
Weak actuator, boost leak?
Engine code?
1.8T AGU..
R135
  24
Saging that maybe it is the actuator as it is a bit weak, I mean it's the original turbo that's done 130k lol
I have an agu
Offline golf-sib
  • Турботазик
AGU, could be a few things, what revs is it happening, how is it holding power, or no power even when boost is in? Also is it drinking fuel?
It may well be the actuator, you running a remap?
1.8T AGU..
R135
  24
About 2.5 - 3k . Power wise it feels very slightly down on power but not much and it isn't drinking much more than normal
