Author Topic: forge split r fitted in recirc mode but getting turbo flutter from air filter  (Read 12202 times)
Offline jamie1989
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline AD1.8T
If its not dumping enough then the spring is prob too weak maybe, is it making a noise under boost similar to a tyre with a loud puncture?? (sorry this is the best way I can describe it haha) [\b]
ummm my 007p does this what is it ?
Offline JimBR
I dont know why your so desperate for a DV...
My forge 007p and Jetex filter give a more than loud enough tshhh with none or the problems your having.
Offline GTIcheeseman
Right servicing it would be an idea , but what grease would you use?
I know what people are saying but I just wanna go back to how it was
Right where on the two pistons do I apply this grease? I have red grease at work or rubber lube grease or lithium grease any of these good?
Offline golf-sib
  • Турботазик
Use the red grease, lithium is a bit to thick and heavy. Basically with the forge DV it's:
1) open the DV up by undoing the top
2) slide the piston out
3) wipe clean piston and inside DV
4) you have 3 o-rings, two that sit inside the dv and act as a air seal between the outer casing and piston - renew if necessary
5) third seal is same as above - renew if necessary, this is located either on the top end of the casing or in the screw top
6) apply grease and reassemble
Not played around with a stock one for a while, it may be similar or it may be a solid unit.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Cheers :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
While we're on the subject of the 007p; if anyone has a spare yellow spring I would take it off your hands
Offline golf-sib
  • Турботазик
Wazzieeeeee
Email forge and say you never got a yellow one in your kit, they will send you one free of charge as there customer service is brilliant.
Thats what I did as I only got one in my kit only, they where very helpful!
1.8T AGU..
R135
  24
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I will give that a go cheers :smiley:
