Author Topic: forge split r fitted in recirc mode but getting turbo flutter from air filter  (Read 12255 times)
Offline golf-sib
  • Турботазик
I'd say either actuator, possible a boost leak, some are very difficult to spot, I've had leaks that I never known about till the silicone split more apart, but since you got an agu most of the vacuum side can be replace with 8mm and 3mm silicone hosing which is cheap as chips.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline GTIcheeseman
Most of the pipes have been replaced... So I'm assuming it is probs the actuator
Could I adjust.my actuator to make it a bit stronger for the mean time?
Offline golf-sib
  • Турботазик
Give the actuator a go, pretty straight forward to do, even better if you have FMIC that goes round via passenger side this means you can easily work on the actuator with the bonnet up :smiley:
1.8T AGU..
R135
  24
Got a rough how to?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I'd say actuator too. Be careful playing with it though, too much preload and you'll kill the engine
How to guide?
Offline golf-sib
  • Турботазик
1.8T AGU..
R135
  24
That's good for setting up but I need to tweak
Ccarefully tweaked it like 1/4 turn max and it's still fluttering
