Author Topic: forge split r fitted in recirc mode but getting turbo flutter from air filter  (Read 12205 times)
Offline GTIcheeseman
Re: dump valve help
« Reply #20 on: 14 June 2012, 06:08 »
I'll take it if it's going for free :)
Re: dump valve help
« Reply #21 on: 14 June 2012, 08:58 »
The dump valve is dumping but not enough so it's back fluttering on the turbo . Could the spring be to strong?
Help?
Offline AD1.8T
Theres a reason everyone is telling you to get a forge recirc ...... Its not like theyve got shares and are trying to make money there trying to help !  :lipsrsealed:
Yes I know but I don't want one hence why I have said it! I want help with a dump valve not a forge recirc , I know my car works fine on one as it had one fitted when I bought it and worked lovely
Offline golf-sib
  • Турботазик
on my AGU, if a too stiff springs in the revs drop slowly with clutch disengaged due to turbo stalling. But I get no chatter noise, I also find it revs over 7200 rpm with a stiff spring in.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline jamie1989
Yours works fine? Mine was running rich with a "dump Valve".(I may add it was on the engine when purchased  :grin:)
I have always been told if you have an air flow meter you shud NEVER run a dump valve.
If you want constructive advise then you should listen to what were saying.
If its not dumping enough then the spring is prob too weak maybe, is it making a noise under boost similar to a tyre with a loud puncture?? (sorry this is the best way I can describe it haha)
Sounds like the dump valve is letting air through it under boost to me.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Tbh the dump valve sounds like a duck quack lol but it still flutters through the filter. When I got it there was no issue with anything it boosted fine and worked perfect
Offline DunnDeal12
  • Limited
people on here cant advise you on a DV because quite simply there crap on the 1.8T engine and cause problems.
007p & 008 FTW
I give up
