Author Topic: mk4 Gearbox for 1.8t conversion  (Read 20051 times)
Offline Ess_Three
Re: mk4 Gearbox for 1.8t conversion
« Reply #20 on: 17 May 2012, 21:10 »
I thought the ABF o2a and the AUM o2j had the same ratios? Wouldn't that mean its quite suited for the turbo? I do like your idea though, Only thing im struggling on ATM is gearbox and how to set up the mounts. As in whats needed for it, do you need to weld new brackets on also?
No welding.
Just use Mk3 16v gearbox mounts...the O2A and O2J 'boxes share the same casing.
..but gaining motorcycles.
Offline Dan_GTi8v
« Reply #21 on: 17 May 2012, 22:55 »
I know brad loves his 16v box but I would seriously recommend getting a box with taller ratios such as the box from a mk3 diesel. The 16v box is designed for 16v engine which has relatively low torque, whereas the diesel box is much more suited to a turbo engine which has a lot more torque and really thrives with the longer gears
your choice but I'd suggest looking into more info on gearbox choice as its quite an important part of your set up :)
Brad has also said he is fitting a VR6 FD to lengthen the gearing. 3.68 to 3.3 IIRC.
yeah hes doing that to his 02j box but up until thats fitted hes running a standard 16v box i believe, the wheel spin must be mental :P
Offline Dan_GTi8v
« Reply #22 on: 17 May 2012, 22:59 »
all 02a and 02j ratios can be found in the clubgti transmission FAQ, give it a read its very informative as is the rest of the gearbox and 1.8t engine section to anyone doing a conversion :)
http://www.clubgti.com/forum/showthread.php?t=115595
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #23 on: 18 May 2012, 18:19 »
thats correct, i am surprised Dan went for the ratios he did TBH and didn't just do this too, the ratios of the 16v box are pretty dam perfect for the 1.8T (wheel spin is present tho as said, unless you really feather in the power), the VR final drive will make it as perfect as you can get for sheer performance, pick up etc, well that coupled with the wavetrac LSD
Its getting sent to Martin (Hotgolf) next week so ill let you know the outcome of it all.. iv been working hard with him and i trust his opinion.
My 02J is getting fully rebuilt by martin so its basically going to be like a brand new box
also fitting a lightened Flywheel at the same time. can't bloody wait :-)
My full mk3 set up is for sale, cable shift, Tower (refurbished looks mint) and early 1.8T shift weight.. think Funkyfive off here is buying my 02A box tho
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline CJA321
« Reply #24 on: 18 May 2012, 19:32 »
See id be interested in the whole set up if it came with the box also!! Would mean only need to source mounts and hydro!!
Only thing im worried about is the wiring.... Everything else not a problem. Do you run OEM managemant?
Callum
Offline Ess_Three
« Reply #25 on: 18 May 2012, 21:07 »
Is Mart supplying the 3.3 FD?
Offline tshirt2k
  • Been there...Done that...
« Reply #26 on: 18 May 2012, 23:28 »
No. He has his own.
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
« Reply #27 on: 19 May 2012, 17:17 »
yeah i have my own FD
Callum, I am using OEM (Audi) Management
Offline Dan_GTi8v
« Reply #28 on: 20 May 2012, 00:55 »
Going from memory here so don't quote me but if I remember right the asd box has the same ratios as the dpa 1st-4th and just has a longer 5th and final drive, so if you put a vr6 final drive into a dpa it would be similar to the asd you would just have the nice long 5th for cruising (90mph just under 3000rpm)
Each to their own though mine is imo perfect for my setup but I don't have the bam like brad just a puny aum :p
Offline F17BAD
« Reply #29 on: 20 May 2012, 13:37 »
AUM is a good lump  :wink:
