Author Topic: mk4 Gearbox for 1.8t conversion  (Read 20052 times)
Offline murraymint
Re: mk4 Gearbox for 1.8t conversion
« Reply #10 on: 17 May 2012, 19:56 »
 :shocked: bargain!!!! Yh I Wudda snapped the sellers hand off too!
 See if you can arrange a courier, I just had a gbox delivered for £30
josh
Offline CJA321
« Reply #11 on: 17 May 2012, 20:07 »
For an ABF? Nice... Only problem is couriers to deliver up here are more than double that haha!!!
Offline Screech16v
  • MK3 20vt AGU
« Reply #12 on: 17 May 2012, 20:08 »
Good price there ,im itching to get mine started but still need a few more parts yet :sad:
Picked my 60k AGU up from my boss in return for 1 weeks work  :evil:
Offline murraymint
« Reply #13 on: 17 May 2012, 20:10 »
Tell your boss il come and do a weeks work for and engine  :grin:
Na the box was for the mk2 Jetta. The courier was from Sheffield to Devon so quite a way, il try and find out the site for ya
josh
Offline murraymint
josh
Offline Screech16v
  • MK3 20vt AGU
« Reply #15 on: 17 May 2012, 20:22 »
 :grin:
Yeah had some right bargains lately, just yesterday collected an abf motor and box,loom,chip ,transponder,ecu,mint drivers door complete,set of cl door trims,and a rear window reg all for £110,now to me that is a good price  :smug:
Offline CJA321
« Reply #16 on: 17 May 2012, 20:44 »
https://www.paisleyfreight.com/
£40, not too bad!
I'll look around for a while more see if i can get a doner local, doubtfull... so will let ya know, cheers  :smiley:
Offline Dan_GTi8v
« Reply #17 on: 17 May 2012, 20:57 »
I know brad loves his 16v box but I would seriously recommend getting a box with taller ratios such as the box from a mk3 diesel. The 16v box is designed for 16v engine which has relatively low torque, whereas the diesel box is much more suited to a turbo engine which has a lot more torque and really thrives with the longer gears
your choice but I'd suggest looking into more info on gearbox choice as its quite an important part of your set up :)
Offline CJA321
« Reply #18 on: 17 May 2012, 21:05 »
I thought the ABF o2a and the AUM o2j had the same ratios? Wouldn't that mean its quite suited for the turbo? I do like your idea though, Only thing im struggling on ATM is gearbox and how to set up the mounts. As in whats needed for it, do you need to weld new brackets on also?
Offline Ess_Three
« Reply #19 on: 17 May 2012, 21:07 »
Brad has also said he is fitting a VR6 FD to lengthen the gearing. 3.68 to 3.3 IIRC.
..but gaining motorcycles.
