Author Topic: painic!! overheating! engine overheating?  (Read 2960 times)
Offline rfn_hodgson
« on: 13 May 2012, 15:17 »
Hey guys i was wondering if i could pick your brains. When im driving along since last night as soon as the turbo kicks in or at around 2000 revs the temp kicks up its not overheated yet but what do you think it is?
Its a 1.8 t 180 bhp auq
Cheers lads
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: painic!! overheating! engine overheating?
« Reply #1 on: 13 May 2012, 16:15 »
the dreaded water pump...
Offline andybod
« Reply #2 on: 13 May 2012, 16:38 »
have you checked/lost any coolant favourate would be water pump or also check fusebox on top of battery make sure that hasn't gone into melt down mode stopping cooling fans kicking in
Offline richw911
« Reply #3 on: 13 May 2012, 17:29 »
Yep  :cry:
Offline rfn_hodgson
« Reply #4 on: 13 May 2012, 17:31 »
Any idea how much to replace water pump?
Offline JC
  • Back in the North.
Offline richw911
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 13 May 2012, 17:42 »
cam belt and tensioner will need doing at the same time too
with the engine running and up to temp is there any water coming back into the header tank via the small top pipe?
Offline rfn_hodgson
« Reply #8 on: 13 May 2012, 18:12 »
The cam belt got changed 6000 miles ago, is it a job I can do my self? And how much to change commercially ??
Offline richw911
« Reply #9 on: 13 May 2012, 18:14 »
You will have to remove the cam belt to fit the new pump  :smiley:
