Author Topic: painic!! overheating! engine overheating?  (Read 2969 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: painic!! overheating! engine overheating?
« Reply #10 on: 13 May 2012, 19:29 »
with the engine running and up to temp is there any water coming back into the header tank via the small top pipe?
Offline harlemex
« Reply #11 on: 13 May 2012, 19:34 »
good point.
a new belt is only about fifteen pounds, but the labour for a new pump is the same as having your belt done anyways. about 250 to 300 all in.  :sick:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 13 May 2012, 19:37 »
just an easy way to see if there's any water circulating  :wink:
My mother in laws partner had the same problem with his XK8, plastic impeller had gone on that too  :rolleyes:
Offline rfn_hodgson
« Reply #13 on: 14 May 2012, 22:16 »
Cheers for all your replies lads been a great help. Been shopping around and you never guess what.... The main dealer works out cheaper wtf I know :) thanks again
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline JimBR
« Reply #14 on: 15 May 2012, 09:48 »
See if there's a TPS nearby. They'll be less than VW for the same parts  :smiley:
