Golf mk3
hardmonkeys
Non starter
Topic: Non starter (Read 1735 times)
mikey_magic
Non starter
29 April 2012, 12:19 »
Hi guys can anyone I've checked all the normal stuff but no fuel going into the block any ideas much need.
Deano2711
1992 VR6
Re: Non starter
29 April 2012, 12:31 »
You need to put some more details up Mate....does it start and cut out or just turn over etc.
mikey_magic
Re: Non starter
29 April 2012, 12:37 »
It just turns over, it's not firing up at all just changed crank,inlet,temp, change dizzy as hall sensor had gone, not firing and plugs are bone dry....
dixie180
Here all the time
Mk3 8v Gti,Mystic Blue the best colour.
Re: Non starter
29 April 2012, 12:46 »
No spark at the plugs could be coil gone.
Rob
mikey_magic
Re: Non starter
29 April 2012, 12:57 »
Got spark at plugs but on fuel going into chamber as plugs don't smell of fuel
dixie180
Here all the time
Re: Non starter
29 April 2012, 13:02 »
What year is your Golf and is it 8v or 16v,etc.
Rob
off_the_cuff
GTI forum regular
Re: Non starter
Reply #6 on:
29 April 2012, 13:21 »
TAke off the fuel rail with inJectors, turn it upside down and turn it over see if fuel comes through, if not could be blocked injectors, or fuel filter. Do u hear the fuel pump prime?
mikey_magic
Re: Non starter
Reply #7 on:
29 April 2012, 17:55 »
It's a 8v year 98 fuel pump is priming no problems there.
dixie180
Here all the time
Re: Non starter
Reply #8 on:
29 April 2012, 18:07 »
Have a look on the search engine on here m8.Lots of people have had similar problems to yours which have pointed towards issues with the ECU and immobiliser.
Rob
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Non starter
Reply #9 on:
29 April 2012, 18:37 »
Which engine code? Suspecting anti-theft controller (control unit that sits behind the light swith), ECU relay - these very very often have bad solder points causing problems with starting.
I suggest that you check the third relay from the left in the upper row. Take it out, disassemble and check solder points... Same for the anti-theft controller.
Maybe this helps. Are there any faults stored in the ECU?
Golf mk3
hardmonkeys
Non starter
