Author Topic: Non starter  (Read 1736 times)
Offline javalin
Re: Non starter
« Reply #10 on: 30 April 2012, 11:38 »
Could also be wiring to the injectors - gets brittle and cracks with age.  Assuming its a multi-point injection (i.e. 2l gti) - there is a common supply feed to the injectors.  Could be a suspect if all plugs are dry, otherwise its may be a single injector control wire.
Look on my blog for car posts - last year repaired mine - took pictures etc.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
