Author Topic: mk4 golf help half way throught conversion.  (Read 5011 times)
Offline cooki2
« on: 18 April 2012, 23:17 »
 Hi everyone my name is mike I live in swansea, not sure if this is in the rite place I have just done a conversion on my mk4 golf from a 1.6 to a 1.8t the problem I have is that the car will start then cut out, I have changed the ecu, clocks , key and ignition barrel. I know its quite vaige but any help would be appreciateted. Thanks mike.
Offline Toby
  • Car - less
Re: mk4 golf help half way throught conversion.
« Reply #1 on: 18 April 2012, 23:19 »
Scanned for fault codes?
Removed imob??
Currently down under
Offline cooki2
« Reply #2 on: 18 April 2012, 23:23 »
Well I only finished it this evening so haven't scanned yet I will have to get some body to do it tomorrow, I thought the imobiliser would have been ok as I used all the new things from the same car. The only thing is that when I press the buttons on the new key nothing happens?
Offline Chris#101
« Reply #3 on: 18 April 2012, 23:35 »
If it was immobiliser related surely it wouldnt start atall!?
Fuel
air
Spark
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Toby
  • Car - less
« Reply #4 on: 18 April 2012, 23:35 »
I think if the clocks are unplugged that makes them need deciding again??
Double check everything
Earth ok????
« Reply #5 on: 18 April 2012, 23:36 »
Not always, they tend to start then cut out straight away.
Offline cooki2
« Reply #6 on: 18 April 2012, 23:39 »
I have fuel coming through and spark as I sed it starts then cuts out after about 3 seconds and I can hear one of the relays clicking, just the let u know I have a 1999 car and the engine is a agu from a 2000.
Offline cooki2
« Reply #7 on: 18 April 2012, 23:40 »
Earth is good.
Offline cooki2
« Reply #8 on: 18 April 2012, 23:50 »
It seems weird to me I mean how could a key work on one car then move the ecu clocks ignition barrel to a diffrent car then it won't work? Surley all this problem with it starting then cutting out 3 seconds later and the fact the key is not working it must be an imobiliser fault? I had a problem with a few of the electrical conections expesially the 3 that are underneath the scuttle pannel on the drivers side 1 of them was differnt it had 3 wires on the 1.6 and 4 wires on the 1.8t so I chopped the 1.8t block off and connected the 1.6 block to it. Anybody come across this before if so what did they do? Any help appreciated.
Offline mcgee9t2
« Reply #9 on: 19 April 2012, 12:32 »
ide say immobiliser kicking in and stalling the car.
