Author Topic: mk4 golf help half way throught conversion.  (Read 5013 times)
Offline cooki2
Re: mk4 golf help half way throught conversion.
« Reply #20 on: 19 April 2012, 15:39 »
That would be brilliant the only thing is I have a brow green and Orange plug? Tried the reverse no luck.
Offline jamie1989
« Reply #21 on: 19 April 2012, 16:15 »
Yeah thats fine
Your green agu goes into the white socket mate.
Then the orange into orange and brown into brown.
You then need to move the purple/white wire from the orange into brown.
When you pull them apart you will see what I mean.  :cool:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline jamie1989
« Reply #22 on: 19 April 2012, 16:20 »
What I did was snip the purple/white wire from the bottom of the brown plug then cut the same wire into the orange wire then connect the two purple/white wires together.
So technically youl have a purple/white wire fully connected from the ECU down to the fuse box.  :smiley:
Its differcult to explain in writing haha
Offline jamie1989
« Reply #23 on: 19 April 2012, 16:24 »
Offline cooki2
« Reply #24 on: 19 April 2012, 16:26 »
I have a purple and white wire but in the other plug I don't. I think mine may be a bit diffrent. Would you be able to pop around tomorrow?
Offline jamie1989
« Reply #25 on: 19 April 2012, 16:28 »
Yeah No props you should be able to pm me now mate.
Pm me your address Il pop up and have a look for you.
Itl be worth it when it starts  :cool:
Offline cooki2
« Reply #26 on: 19 April 2012, 16:29 »
I don't know how to pm lol. Have u got my number? If u have give me a ring when convinient if you can  :grin:.
Offline jamie1989
« Reply #27 on: 19 April 2012, 17:06 »
No props mate ill ring after work  :smiley:
Offline gaz_mk1_golf
« Reply #28 on: 20 April 2012, 09:36 »
alright mate try this just got mine sorted this morning put ya car in to reverse and start it with ya foot on the clutch if that works cut the plug off the reverse light sensor on the gear box and twist the 2 wires together mines running sweet now
Offline jamie1989
« Reply #29 on: 20 April 2012, 19:17 »
Cars now running sweet. Nice to meet you Mike good luck putting everything back together  :cool:
Then start modding  :evil:
