Author Topic: rear knocking after shocks change...  (Read 4510 times)
Offline Deano2711
  • 1992 VR6
Re: rear knocking after shocks change...
« Reply #10 on: 22 March 2012, 12:09 »
When the garage changed my rear springs he did not tighten the top nut properly and I had the same noise you are getting. I went back and played my mouth a bit but was easily sorted.
« Reply #11 on: 22 March 2012, 13:42 »
Thanks Wayne - No I didn't - just suspension weight on it.
Will check this out tonight!
Thanks!
I suspect they are loose in that case.
Offline javalin
« Reply #12 on: 22 March 2012, 16:06 »
I suspect this guy has it right - its a BMW forum link but he recons the top shock mount was the problem for the OP.  Mine is similarly buggered, so will check bolts tonight just in case and then plan to change the shock mount rubber.  Interesting video in the post though.
http://forums.bimmerforums.com/forum/showthread.php?t=1484279
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #13 on: 22 March 2012, 16:32 »
Your post earlier said you fitted new ones, if not then yes change them.
Offline javalin
« Reply #14 on: 22 March 2012, 17:49 »
ok sorry not clear, new top mounts fitted but not shock rubber...
Offline javalin
« Reply #15 on: 26 March 2012, 08:42 »
okay - so new front shocks installed at the weekend, and new shock rubber installed in the rear shocks.
It knocks like a bugger now from the o/s/r - sure I've put it together correctly and that its tight.  Mainly when accelerating.
Wife sat in the back at the weekend and said the top mount wasn't moving at all.  She seemed to think the knocking was further forward, i.e. beam bushes, but not 100% sure about that.  Sounds to me like the shock.
Any ideas...........?
James
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #16 on: 26 March 2012, 09:03 »
Faulty shock unit maybe?
Offline javalin
« Reply #17 on: 26 March 2012, 09:11 »
mmmm - don't think so - both felt much the same to me (i.e. effort to pull the piston up).
Offline brett
« Reply #18 on: 26 March 2012, 09:40 »
i had similar a while back got some shocks of someone and said they was ready to go on the car ,only to find that the metal circlip missing on the shaft of the shock,maybe worth a look,brett
Offline javalin
« Reply #19 on: 26 March 2012, 21:02 »
I think i've found the issue.  The o/s/r wheel rocks top to bottom when pulled,  n/s/r not so much.  Thats bearings isn't it?
Couldn't find a fault, or get the rear stuts to move....
« Last Edit: 27 March 2012, 08:30 by javalin »
