Author Topic: rear knocking after shocks change...  (Read 4508 times)
Re: rear knocking after shocks change...
« Reply #20 on: 26 March 2012, 21:33 »
I think i've found the issue.  the o/s/r wheel rocks top to bottom when pulled.  the n/s/r not so muvh.  thats bearings isn't it?
Yep, bearing has had it.
Offline javalin
« Reply #21 on: 28 March 2012, 14:18 »
Garage have adjusted the bearings (local vw speciallist), as they are adjustable apparently?  It sounds like they've just tightend the nut and put a new split pin in.... Hmmmm.
Knocking continues....., but less noise and actual vibration/feedback in the car.  Mainly on acceleration/braking.
I'll check it out again tonight and see, but suspension continues to feel solid - at least I can't make it knock.  So I guess either the bearings have had it and new ones required, or maybe beam bushes.  There is not much left thats not new...
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #22 on: 28 March 2012, 17:00 »
Long shot but are you sure the exhaust is not toucing the rear beam.
Offline tweed
« Reply #23 on: 28 March 2012, 17:03 »
Seen that happen before
Offline javalin
« Reply #24 on: 28 March 2012, 17:08 »
interesting - i'll check.
there is still play in the rear wheels.....  back to the garage i think....
james
Offline Bellend
« Reply #25 on: 28 March 2012, 18:36 »
james
You know there is always a small bit of play, yes?
Where all my moneys went.
Offline javalin
« Reply #26 on: 28 March 2012, 20:36 »
There is a different amount of play between o/s/r and o/s/l.  It was fine immediatly after it was ajusted but now (24 hours later) its back to where it was - so something is not right.
Still... Back in the garage again today....
James
(edited)
« Last Edit: 30 March 2012, 09:29 by javalin »
Offline javalin
« Reply #27 on: 30 March 2012, 13:21 »
FIXED.
The rear part of the exhaust wasn't installed correctly and was knocking.  I think the bearings adjustment helped too though.
thanks all for your help!
James
Offline AudiA8Quattro
« Reply #28 on: 30 March 2012, 14:18 »
james
A VERY small amount of play, pretty much zero, and the wheel should spin smoothly.
