Author Topic: rear knocking after shocks change...  (Read 4503 times)
Offline javalin
« on: 22 March 2012, 08:45 »
Hello
Changed my rear shocks last night for a pair of Meyle ones, old ones had oil leaks and generally buggered.
Knocking from the o/s/r now when bumpy roads, not all the time.  Can't get it to make a noise when bouncing or rocking the car by hand.
Any ideas?  Sounds like the shock bouncing the in the turret?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: rear knocking after shocks change...
« Reply #1 on: 22 March 2012, 09:05 »
Did you check the top mounts on replacement?
Offline javalin
« Reply #2 on: 22 March 2012, 09:09 »
oh yes, just going to add - new top mounts and new bump stop & covers fitted.
Ta
James
« Reply #3 on: 22 March 2012, 09:19 »
Assembled incorrectly maybe or could the soggy old shocks have been masking worn out rear beam bushes?
Offline javalin
« Reply #4 on: 22 March 2012, 09:24 »
assembled fine,and same for both sides, was very careful to strip and rebuild as was originally built.  Could be beam bushes I guess.
blurry picture of assembled strut.
James
Offline javalin
« Reply #5 on: 22 March 2012, 09:51 »
and for laughs the old shocks - can you tell which failed the MOT....?
« Reply #6 on: 22 March 2012, 10:38 »
Bit moist that.  :laugh:
Offline VR6_Wherry
« Reply #7 on: 22 March 2012, 10:44 »
 :grin:
Looks ruined!
To be fair 'the better one' doesn't look great either! :laugh:
« Reply #8 on: 22 March 2012, 11:43 »
Did you tighten the top nut with the weight of the car on it, worth checking they are tight in anycase.
Offline javalin
« Reply #9 on: 22 March 2012, 11:47 »
Thanks Wayne - No I didn't - just suspension weight on it.
Will check this out tonight!
Thanks!
