Author Topic: switch  (Read 4173 times)
Offline Dis00
  • MAN i JUST LOVE THE ICE CREAM
switch
« on: 26 May 2005, 01:18 »
as i couldnt find a remote lead for the amp turn on i have decided to put a switch it and i was wondering if i bought a vw mk4 heated seat switch i could hook it up to that so the light on the switch is on when the amp is on so i dont forget to turn it off
if this is possible does anyone know where i can get the switch from
Cheers Deano
Offline Mr Blue
Re: switch
« Reply #1 on: 26 May 2005, 12:33 »
you can wire it to a rear light bulb. so when you switch your lights on the amp turns on.
just an option
Offline Dis00
Re: switch
« Reply #2 on: 26 May 2005, 12:34 »
that means i would have to have my lights on all the time
Offline Mr Blue
Re: switch
« Reply #3 on: 26 May 2005, 12:50 »
chav it out by wiring it to your fogs :grin: kidding :tongue:
yaeh i would then wire it to a spare switch. a hazzard switch or something
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: switch
« Reply #4 on: 26 May 2005, 13:17 »
You will indeed be able to use a standard switch (heated seat will be fine).
If you use an iginition live supply to feed the switch, then amp/s will only work when the key is in the ignition and the switch is depressed.
That way, even if you forget the switch, it will still be turned off when you kill the ignition.
The greatest leveller of them all - the Carousel
Offline Splinter
Re: switch
« Reply #5 on: 26 May 2005, 13:20 »
Just about to say, link it to an ignition live with a smallish wire. One found behind stereo amongst other places. Stupid to put it on a switch IMO.
" Do it today, Don't wait until tomorrow "
Offline Dis00
Re: switch
« Reply #6 on: 26 May 2005, 15:45 »
ive tried evry wire behind the radio and no one kills the power the the amp when the radio is off and the key is out so thouight easiest way would be to put a switch on
Offline Splinter
Re: switch
« Reply #7 on: 26 May 2005, 19:03 »
Oh :sad: well there should be both a remote wire (or two) from the radio and a live feed from the ignition switch. If you haven't got a tester, use a 12v bulb or little motor or something.
Any 12v switch will work if you go down that route and would be the best alternative. Don't wire it up to your lights!!  :grin:
Offline Dizzie
  • Make friends with your fast
Re: switch
« Reply #8 on: 26 May 2005, 23:53 »
what about wiring it to the ignition?
+15 wire off the key.
Mk4 Golf 150PD
Offline diagnosis-dub
Re: switch
« Reply #9 on: 06 January 2006, 01:13 »
What about taking the cover off the fuse box and running a feed from the pole that's ignition live, MK4's are handy like that as they have the poles above the fuses so you just have to put a ring terminal on it.
