Author Topic: switch  (Read 4180 times)
Offline MrDan
Re: switch
« Reply #10 on: 09 January 2006, 11:50 »
Wire it to your heated rear window switch as this will definatley have a switched live! thats how i did my headunit as my wiring was a mess
Offline mk2singh
Re: switch
« Reply #11 on: 30 January 2006, 22:59 »
jus wire it to ur 12+ on ur headunit because that only turns on when the key is in the ignition and the headunit is on, so eveytime u take the key out the amp will turn off too, dats how i did my m8s car.
Offline Dom Mk3
  • Insert wit here
Re: switch
« Reply #12 on: 30 January 2006, 23:18 »
Do you work for sextons? Oh no wait, my bad, they used the clock  :grin:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: switch
« Reply #13 on: 02 February 2006, 18:43 »
If you remove the dash under the sterring wheel, then there is an ign liove connection there, but like everyone is saying there is at least 1 behind the radio, i know cause i use em :cool:
kingturbo
Re: switch
« Reply #14 on: 07 February 2006, 18:20 »
what stereo are you using if its gamma doesnt the autoleads lead that plugs into the back with the rcas on come with a remote wire?
