Author Topic: Wheel bearings help!!  (Read 3669 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 18 August 2011, 11:33 »
My other MK3 GTI 8v had an advisory for both rear wheel bearings.
The MOT tester said they needed tightening up as there is to much play in them.  Soooo!  How do I tighten the rear wheel bearings?  She is a 1997 2.0 8v Golf GTI......Not my VR6!
Thanks in advance  :smiley:
« Last Edit: 19 August 2011, 19:32 by Godzilla »
Offline danmusic24
Re: Wheel bearings help!!
« Reply #1 on: 18 August 2011, 11:36 »
remove wheel,remove centre bearing cap,remove split pin,tighten nut(not to tight,just over hand tight)...job done! better to replace them :smiley:
Offline mellow yellow
  • A Driffield Dubber!
« Reply #2 on: 18 August 2011, 12:05 »
same question from me but about the fronts  :smiley: diy job?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #3 on: 18 August 2011, 12:22 »
Thanks mate  :wink:
Offline AudiA8Quattro
« Reply #4 on: 18 August 2011, 12:24 »
Press needed for the fronts.
For the rears DO NOT overtighten the nut, hand tight only.
Offline danmusic24
« Reply #5 on: 18 August 2011, 12:29 »
to be honest i would not take the gamble and tighten them! replace them its not a bad job to do on rear...
Offline nikkiy9
« Reply #6 on: 18 August 2011, 13:32 »
fronts you can diy if you know what you are doing, done many bearings without a press
« Reply #7 on: 18 August 2011, 14:38 »
It is possible with a large vice, but much much easier with a press.
What method did you use?
Offline nikkiy9
« Reply #8 on: 18 August 2011, 14:58 »
I use the good old hammer and socket method, done Volvo's, ford's, fiat's and vw's all this way, not one issue yet and the Volvo has just done 35k since I done them both
« Reply #9 on: 18 August 2011, 15:07 »
can you do a little how to for me, gonna give it a bash  :smiley:
