Author Topic: Wheel bearings help!!  (Read 3678 times)
Offline AudiA8Quattro
Re: Wheel bearings help!!
« Reply #10 on: 18 August 2011, 16:48 »
I've seen several bearings that have needed several tonnes of pressure to release, there was no way a hammer and socket would of done it.
Its a bad idea generally when fitting new ones, as damage can occur.
Take the hub off, and take it to a garage if you haven't go a press or a large vice.
Offline nikkiy9
« Reply #11 on: 18 August 2011, 17:16 »
I use the good old hammer and socket method, done Volvo's, ford's, fiat's and vw's all this way, not one issue yet and the Volvo has just done 35k since I done them both
can you do a little how to for me, gonna give it a bash  :smiley:
i would but i'm not in the north east any more, why not get THESE to do it for you? he's a bloody good bloke and knows what he's doing also
« Reply #12 on: 18 August 2011, 20:23 »
Much easier with a press.
« Last Edit: 05 October 2011, 17:03 by Wayne »
Offline AlexMozza
« Reply #13 on: 18 August 2011, 22:15 »
How much would a garage charge to do the fronts...Or how much is a press!
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
« Reply #14 on: 18 August 2011, 22:16 »
Depends how friendly you are with the garage, if you take the hub in it shouldn't be too much.
You can get a budget press off ebay for 100 quid, i've got one, and it hasn't failed me yet.
Offline AlexMozza
« Reply #15 on: 18 August 2011, 22:20 »
Coolio :)
for the price at a garage might aswell ebay it then!
That way I'll be sorted when mine go!
2001 Satria GTi
Formula 3 Mechanic
Offline dan_apps
  • too low for british roads!
« Reply #17 on: 18 August 2011, 22:32 »
^^ thats a bargain right there to be fair!
Offline gasketface
« Reply #18 on: 19 August 2011, 12:49 »
I'm gonna buy one of them right away.The bolt through wife's neck has seized again and it's a bugger to get it out with a Dremel. :laugh:
« Reply #19 on: 19 August 2011, 13:46 »
Its very basic, but it certainly does the job  :smiley:
