Author Topic: Advice on undo-ing top mount front suspension please  (Read 2123 times)
Offline mrcooke
I Had the deep ring spanner on it and the the allen key but i just couldn't loosen the bastard; the allen key just wanted to mashup the the bolt. Any ideas on how i can do this? sorry for my ignorance
Offline dragongreengolfgti
  • my golf gti mk3
Re: Advice on undo-ing top mount front suspension please
« Reply #1 on: 11 June 2011, 23:52 »
i take it your doing this on your drive etc lol what you need is a good quality allen key i.e snap on which dosn't twist,snap or round  but also a good 6 sided swan kneck spanner either that or a air powered tool if that fails you need to call superman  :smiley:
« Reply #2 on: 12 June 2011, 00:14 »
Pop to your local garage and get them to crack them off with an air gun.
Offline Bellend
« Reply #3 on: 12 June 2011, 00:44 »
This or force an oil filter chain wrench under the top cup.
Where all my moneys went.
Offline mrcooke
« Reply #4 on: 12 June 2011, 10:02 »
thanks guys, i think i'm gonna bow out gracefully and go to a garage on this one
Offline Bellend
« Reply #5 on: 12 June 2011, 13:21 »
Give one of them a fiver and they'll air gun them off, take the top plates off, air gun the nuts underneath that then just put it back with a ratchet and take a slow drive home and undo.
Offline mrcooke
« Reply #6 on: 12 June 2011, 15:26 »
sounds like a plan. cheers
Offline snifferdog
« Reply #7 on: 12 June 2011, 17:01 »
I took mine to a local garage, took 5 mins and cost tenner. Its the best way!  :grin: :laugh:
Offline AudiA8Quattro
« Reply #8 on: 13 June 2011, 14:33 »
If i remember right, a spark plug socket works at a treat on this, one with flats for a spanner to engage.
Then use an allen key through the middle, you can get the laser tool with a big handle.
I wouldn't recommend using air tools on shock absorbers, you can damage the seals.
Battery powered wrench would be fine.
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 13 June 2011, 15:13 »
+1 or soak them in wd40/dd, fill till its full to the top and leave till next day, thats what i did and it worked.
*****MK3 Anniversary*****
*****MK4 GTI T*****
