Author Topic: which panel filter?  (Read 7133 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: which panel filter?
« Reply #20 on: 21 June 2011, 23:49 »
got a pipercross one, along with a new unbutchered air box :D
cause apparently when drlling the airbox they thought it'd be good to drill the top too so unfiltered air was being drawn straight into the throttle body...
GENIUS!  :huh:
good engineering knowledge i guess  :grin:
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« Reply #21 on: 22 June 2011, 00:10 »
Quote
Offline Sam
  • Sam I am
« Reply #22 on: 22 June 2011, 01:39 »
GENIUS!  :huh:
Yeh, I taught him everything I know
Offline delirical
  • Like a g60
« Reply #23 on: 23 June 2011, 14:16 »
A friend of mine took the plastic cone part out of my airbox and now at cruising speed i have a very annoying droaning noise a bit like.. warb warb warb warb... i'm sure its because of what he has done.. he threw the bits away  :evil: anyone else experienced this?
Anyone got a airbox for a g60 or golf if they are the same?? i dont like the noise  :sad:
Offline rob.043
« Reply #24 on: 23 June 2011, 15:17 »
got a trumpet for a digi 8v box, if it'll fit its yours.
Offline andynorfolk
« Reply #25 on: 23 June 2011, 19:40 »
oops... i just cut the cone out in the new one i got as it looks like all it's doing is restricting the air flow... was that a stupid thing to do?  :undecided:
Offline rob.043
« Reply #26 on: 24 June 2011, 09:11 »
the cone/trumpet should pull out without breaking (so can be replaced if you prefer it), depending how you go about it!  It is there to reduce noise primarily, and will have an effect on restricting flow.
Offline delirical
  • Like a g60
« Reply #27 on: 24 June 2011, 11:15 »
Let me know if you get a bloody annoying droaning noise when cruising.. tunes have to be turned up to cancel it out, actually gives me a headache!
Offline delirical
  • Like a g60
« Reply #28 on: 24 June 2011, 11:16 »
That would be awesome mate, apart from your in scotland... can you find out how much postage would be, i need the trumpet and the internal bracket i guess. cheers
Offline rob.043
« Reply #29 on: 24 June 2011, 13:56 »
PM'd
