Author Topic: which panel filter?  (Read 7131 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
which panel filter?
« on: 09 June 2011, 17:53 »
i need a new air box as mine was butchered when i got it and the muppet actually drilled holes in the top of the airbox as well as the bottom :S
so im gonna upgrade the filter too... i have used pipercross panel filters in the past and have always been good, anyone else got any suggestions? i've always though k&n was just a name to sell cheap rubbish under...
Offline AudiA8Quattro
Re: which panel filter?
« Reply #1 on: 09 June 2011, 17:55 »
I've always used k&n.
Offline andynorfolk
« Reply #2 on: 09 June 2011, 18:02 »
i had a k&n induction kit on my bravo 1.6 and it just did nothing... so then i ran a pipercross filter in the standard airbox and it seemed to run infinitely better
Offline jmsheahan
« Reply #3 on: 09 June 2011, 18:26 »
Just put a standard one from VWS in there. Fiver. Job done.
Offline mk2bal
« Reply #4 on: 09 June 2011, 18:31 »
As above. If 16v, drilled front corner, snorkel removed, wing blanking trim removed,  £5 vws filter. In winter I run no snorkel at all jus a great big hole out front, in summer I run some convoluted cable duct attached to front of snorkel as cold air duct, but the snorkel itself is chopped off inside so I still get the noise with only a few less db's.
Offline Sam
  • Sam I am
« Reply #5 on: 09 June 2011, 18:37 »
Standard is best  :smiley:
Offline andynorfolk
« Reply #6 on: 09 June 2011, 18:43 »
i want the airbox kept completely standard, but the standard paper filters are let's be honest fairly crappy and you need to keep replacing them...
reckon i might just go with a pipercross panel filter
« Reply #7 on: 09 June 2011, 20:56 »
K & N is a good choice.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #8 on: 09 June 2011, 21:42 »
It's an air filter FFS.  Save your money and get a standard one.
Offline dubber36
« Reply #9 on: 09 June 2011, 21:50 »
How true.
