Author Topic: Coil pack recall  (Read 24227 times)
Offline Aaron_RJ
Coil pack recall
« on: 22 February 2011, 21:05 »
just to help out there is a recall of a VAG camapign with recalls of nearly all FSI/TFSI/MPI engines
1.8 T-6.0 MPI
For the 2.0 TFSI the affected engine codes:
AXX-BGB-BHZ-BPG-BPJ-BUL-BWA-BWE-BWT-BYK-BYD
Ignition coils with part number- 07K 905 715F, 07K 905 715D, 06H 905 115, 06F 905 115F do not need replacing as they are not affected if your ignition coil isnt one of the above part numbers they will be replaced with the revised part 07K 905 715F
hope this helps and you can check your car to see if you can have some free coil packs
just phone your dealer and if your car is affected as above part number list they will book you in FOC
Aaron
P.s Im an audi technician before anyone asks if its true haha  :drool:
« Last Edit: 22 February 2011, 21:23 by Aaron_RJ »
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP |Sportlines |Goodrich hoses|Milltek TBE
Offline Stitch
Re: Coil pack recall
« Reply #1 on: 22 February 2011, 21:38 »
Had mine fitted today when it was in for something else. 4 new coils (car is a 56 plate).
Offline weston
« Reply #2 on: 23 February 2011, 09:27 »
Saw this on another forum to. So without booking any work you could get this work done foc if the codes match?
Offline Saint Steve
« Reply #3 on: 23 February 2011, 11:10 »
Just had mine replaced too this morning. Car is feb 07  Ed30.
My car feels alot more responsive since having the coilpacks replaced??
Odd but im not complaining :cool:
Offline 2007GTI
« Reply #4 on: 23 February 2011, 11:24 »
is it easy to check without going to dealer?
Offline VWjon
« Reply #5 on: 23 February 2011, 11:44 »
Where do I check what coil pack part numbers I have?
MKV Black GTi ¦ 3 Door ¦ Manual ¦ Leather ¦ Monza II ¦ Armrest ¦ iPod ¦
Mods:- Smoked Wing Mirror Indicators
Future Mods:- RNS510 Stereo
Offline Phil1980
« Reply #6 on: 23 February 2011, 11:59 »
Yes how can I check if mine is eligible to have this changed free of charge?  Will take it in asap if i'm eligible
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline Snooze
« Reply #7 on: 23 February 2011, 19:11 »
Cheers for the info.  How do I check my car to see if mine need changing?
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline biggaz41
« Reply #8 on: 24 February 2011, 08:58 »
I looked in the front cover of my handbook - saw engine code AXX and believe that means mine needs to be replaced. That's where I'd have a look and then if your engine code matches those Aaron listed, I'd take it in. Not sure how to check part number on the ignition coil packs though  :sad:
Currently in having the timing belt and water pumped changed with my local mechanic (not a sniff of me going to the stealers!) so once that's done, will take it in and get eligibility confirmed and, if necessary, coil packs changed.
Offline bacillus
« Reply #9 on: 24 February 2011, 09:19 »
The number is etched on the top side of the coil pack but only visible if the wiring connector is removed.
Without traction power is nothing!
