Author Topic: how do i fit uprated headlight loom on my mk2 anyone ??  (Read 21799 times)
Offline SoundillusioN
Re: how do i fit uprated headlight loom on my mk2 anyone ??
« Reply #10 on: 05 February 2011, 05:01 »
Would that only do the main beam?
I ve made one but only got dipped so i need to re do one to work the spots aswell.
Which one mine or the one on ebay.. mine covers everything, dipped, main and spots with a realy for each.
that ebay one looks lame and doesn't even look like it has enough connections.. In fact I can't even see any bulb plugs?
Yeah your one. Thats what i want it to do cos at the mo there is a massive difference between dipped and main. Cant work out how you did it only using a relay for each side rather than a relay for dipped and one for main
I've got three relays, I have changed the setup twice since fitting and may change again and add a fourth relay but the principle is the same.  The third relay on mine is dedicated to the spots.  Each relay has 2 outputs and the OEM loom remains intact providing the signal.
Take a picture of your upgrade kit rather than the ebay one for a closer look at what you have.
Offline 92Mk2Gti
« Reply #11 on: 08 February 2011, 13:27 »
Are these things actually worthwhile, I really need to do this but don't fancy making my own, fitting it is going to be hard enough for me
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220735479997
1992(J) Golf GTI 8v Gone but still in the family
2003(53) Golf GTI 180
Offline Adamdubz
« Reply #12 on: 08 February 2011, 23:22 »
put mine in the other day sooooo worthwhile  :grin:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #13 on: 09 February 2011, 18:19 »
Buy this one if any....
http://cgi.ebay.co.uk/vw-golf-mk2-headlight-wiring-loom-upgrade-kit-/280624154860?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415680c8ec#ht_783wt_905
Worth every penny... I was looking at making a batch but the parts cost just as much as buying the loom....
Also buy better headlight bulbs like Osram/Phillips nightbreaker plus... also worth every penny
For More Info Click To See;
« Reply #14 on: 10 February 2011, 09:23 »
yeah know what you mean, the ones i make come out at around £27 in parts so i make bugger all money on em. not really worth my time
« Reply #15 on: 10 February 2011, 13:20 »
Only made mine for me because I wanted it to be a certain way and quality, they're not profitable unless you use cheap sh*t and if that happens you may as well not bother.
Offline 92Mk2Gti
« Reply #16 on: 10 February 2011, 13:25 »
Cheers guys, just bought one will report back once it's fitted   :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #17 on: 11 February 2011, 12:10 »
Is that one worth £38 delivered ??
How much are your ones rubjonny ??
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #18 on: 11 February 2011, 12:29 »
IMO Yes... Quality Relays, Wire and all comes with flexi Conduite!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #19 on: 11 February 2011, 13:17 »
Might have to invest then  :smiley:
