Author Topic: how do i fit uprated headlight loom on my mk2 anyone ??  (Read 21800 times)
Offline Adamdubz
need help as dont wana get to it and not no what to do x
Offline dom
  • Back in a Mk4
Re: how do i fit uprated headlight loom on my mk2 anyone ??
« Reply #1 on: 03 February 2011, 22:56 »
One of these will do the trick :wink:
http://cgi.ebay.co.uk/VW-Corrado-Mk2-Golf-Uprated-Headlight-Wiring-Loom-/220720050978?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3363f0b322#ht_500wt_1156
I priced up making my own, but by the time you add everything up the cost isn't much less than the eBay one. It's a p!ss easy install, and comes with instructions.
Offline Adamdubz
« Reply #2 on: 03 February 2011, 23:01 »
no no i have it but i need to no how to put it in as i dont wana talk it all out and then be like ah
Offline SoundillusioN
« Reply #3 on: 03 February 2011, 23:03 »
Did it not come with instructions?..... I have a diagram of the one I made in my project thread... let me dig it out and the see if I can help.
Firstly though, are the relays already wired in this upgrade you have?
Offline Adamdubz
« Reply #4 on: 03 February 2011, 23:07 »
yup it did but wana check it all with you guys because you lot no everything :D and yup it  all together and ready to go on the car
« Reply #5 on: 03 February 2011, 23:10 »
Taken from HERE which has some blurb with it (not a guide) have look and ask away.  :wink:
Offline weazgti
« Reply #6 on: 04 February 2011, 13:11 »
Would that only do the main beam?
I ve made one but only got dipped so i need to re do one to work the spots aswell.
« Reply #7 on: 04 February 2011, 13:50 »
Which one mine or the one on ebay.. mine covers everything, dipped, main and spots with a realy for each.
that ebay one looks lame and doesn't even look like it has enough connections.. In fact I can't even see any bulb plugs?
Offline weazgti
« Reply #8 on: 04 February 2011, 14:54 »
Yeah your one. Thats what i want it to do cos at the mo there is a massive difference between dipped and main. Cant work out how you did it only using a relay for each side rather than a relay for dipped and one for main
Offline Alec
« Reply #9 on: 05 February 2011, 04:38 »
