Author Topic: how do i fit uprated headlight loom on my mk2 anyone ??  (Read 21801 times)
Offline bodga
  • F reg GTI 16v
Re: how do i fit uprated headlight loom on my mk2 anyone ??
« Reply #40 on: 26 September 2011, 21:20 »
I = current (amps)
V = volts
W = watts
I x V = w
10 x 12 = 120w
headlamps are 55w each so yes it should be ok to protect the dim dip circuit or main beam :nerd:
You also need to make sure you use a fuse smaller than the cable you are using can handle ( if you only have 10A cable protect the circuit with a fuse no bigger than 10A)
( this is the only bit ive learned from my college days that ive found any use for :laugh:)
Offline cняis
« Reply #41 on: 27 September 2011, 19:23 »
FYI im running 17.5A cabling and its fine  :smiley:
