Author Topic: how do i fit uprated headlight loom on my mk2 anyone ??  (Read 21823 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: how do i fit uprated headlight loom on my mk2 anyone ??
« Reply #30 on: 14 February 2011, 23:44 »
I think they're pretty pants tbh, the beam patterns improved quiet a bit when i stuck some Phillips X-treame bulbs in but i wouldn't say they were spectacular by any means. And as for the output from the OEM fogs...pffft!
« Reply #31 on: 15 February 2011, 10:19 »
its a problem on a large number of cars really, many dont have any relays for the lighting system and if the power from the lights goes ign switch -> fusebox -> light switch -> lights then any car will suffer over the years from the same issue.
heres a great guide from matey-matey, take you thru everything thats needed. jsut adapt the diagram so there are 2 dim-dip relays rather than just 1!  main thing is to get the right wires to the right pins on the light plugs, plus get all the relay pins correct:
http://www.matey-matey.com/uprated_headlight_wiring.shtml
you can get all the bits you need from http://www.polevolt.co.uk
if you get the spotlight plugs make sure you get the right Packard Timer ones with 2 locking pegs rather than 1. made that mistake before and ended up with 10 plugs that i couldn't use  :grin:
Offline cняis
« Reply #32 on: 15 February 2011, 13:48 »
i adapted the matey matey diagram so i didnt cut into the OE loom. I just plug into one of the OE H4 plugs  :smiley:
« Reply #33 on: 15 February 2011, 14:02 »
yeah put a pair of spades on the trigger wires, pop em into the h4 plug. forgot to say thats what i do as well :)
Offline emery1990
« Reply #34 on: 20 February 2011, 21:32 »
RJ, is this  near enough the same as what I've just done, The diagram seems easy enough to understand. With the electrical knowledge still fresh in my mind think itd be best to do this sooner rather than later!  :grin:
Offline Adamdubz
« Reply #35 on: 21 February 2011, 15:54 »
ok how do you do this for fogs?? I no nothing to much about electrics in the car i did my spots and my dipped beam but fogs really need to be done
« Reply #36 on: 21 February 2011, 16:07 »
emery: what have you done already?
adam: fogs are already relayed, or at least they should be! you probably wont notice a massive difference as they aint that bright due to the light pattern.  its worth taking them out to see how good they are inside, usually by now all the chrome has come off the back of the housing which makes them really crap even by mk2 standards. if this has happened then get yourself a pair of mk3 golf fogs and swap the backs over. the mk3 ones are metal rather than plastic so much better quailty than the mk2.
Offline Adamdubz
« Reply #37 on: 22 February 2011, 00:52 »
ok cool i think i will get a new set as the faces of mine are all battered and nasty and get some cheep mk3 ones and swap the backs
 :grin:
Offline 92Mk2Gti
« Reply #38 on: 14 March 2011, 12:50 »
Cheers guys, just bought one will report back once it's fitted   :undecided:
I can see in the dark  :laugh:
1992(J) Golf GTI 8v Gone but still in the family
2003(53) Golf GTI 180
Offline mk2rolf16v
« Reply #39 on: 24 September 2011, 20:39 »
RJ- from what i can see youve used 10amp fuses while all the other wiring harnesses on market use 20amp.... is 20amp too much for a mk2??
