Author Topic: Dan_GTi8v, 20vt project  (Read 129154 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Dan_GTi8v, 20vt project
« Reply #170 on: 08 November 2011, 14:00 »
wires, wires, wires everywhere  :laugh: what do they all do ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
  • Been there...Done that...
« Reply #171 on: 08 November 2011, 14:34 »
Thought the idea if moving the battery was to tidy up the bay? Does look a bit hectic tbh.
Mk3 ABF 16VT Megasquirt V3
Offline Dan_GTi8v
« Reply #172 on: 08 November 2011, 16:43 »
Its a work in progress we're not all blessed with garages and/or cover from the rain and dark  :laugh:
Bits and pieces are slowly getting done, just hard up for time especially as it gets dark so early now and this is my only car so I need to finish whatever I start  :sad:
It does look better now just need time for an update
Offline Dan_GTi8v
« Reply #173 on: 16 November 2011, 23:17 »
Getting close to the bay being finished now, thinking I'm gonna be getting a 42DD stealth catch can at some point as its the only one I can find with 19mm inlets. Does seem a lot of money for what it is though  :undecided:
I've sorted out the boost piping now and it looks much better, tomorrow gonna play around with the catch can at a last attempt of making it look half decent before I give in buy some new pipe and stealh can. Also gonna move the washer tank to drivers side.
Fingers crossed for pictures!
Offline tshirt2k
« Reply #174 on: 17 November 2011, 15:25 »
If you want the can out of the way, put it where the carbon canistor went. Just has the pipes showing.
Comes out behind drivers side light.
Offline Dan_GTi8v
« Reply #175 on: 17 November 2011, 15:36 »
great minds think alike :p this is what I've decided I'm going to do, just ordered another length of pipe :) also ordered a load of water washer pipe so as soon as that comes I'll do it all together. Going to get a new can as well, seems to fill quite quickly and this ones a pain in the arse to empty
Offline tshirt2k
« Reply #176 on: 17 November 2011, 18:22 »
If it fills quick, your engine may be breathing heavy. Are you sure its being circulated back into the engine right?
That should stop it filling quick.
My can has a drain plug underneath, that you can get to by putting your hand under the bumper. I just don't like the fact that it isnt sealed very well
Offline Dan_GTi8v
« Reply #177 on: 17 November 2011, 18:28 »
how would I know if it was circulating right? pretty much all I've done is take out the pcv valve and put a can in its place, and made the hoses longer
When I say it fills quick, it's never actually filled but I'd say it fills maybe a 1/4 up the indicator tube in just over a month (iirc thats the last time I checked it) My can looks the same as yours, just has a different brand name on the top, thinking about it if I move it so I can get access to the underneith it would be much easier to empty and I may not need a new one  :smiley:
Offline tshirt2k
« Reply #178 on: 17 November 2011, 22:45 »
A quarter a month is nothing. have you filled it with scourers? cant remeber reason why. but think it helps vapour condense easier
« Last Edit: 17 November 2011, 22:49 by tshirt2k »
Offline Dan_GTi8v
« Reply #179 on: 17 November 2011, 23:22 »
Nothing inside it just empty can. I thought1/4 was a lot, I've read of only half being filled in 6 months
