Author Topic: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa  (Read 5914 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 21psi yeeeaaaahhhh hhhhhaaaaaaaaaaaaaaaa
« Reply #10 on: 22 May 2010, 15:59 »
back up again
Offline MaXXeH
  • Golf MK5 GTI
« Reply #11 on: 22 May 2010, 18:43 »
lol funny you say that.
Now mine is spot on 25psi and holding 21 to 5.8k
AGU
It is abit colder down here to day and now only hitting 15psi.    It is ment to be real hot tomorrow it will be the real test!
Offline MaXXeH
  • Golf MK5 GTI
« Reply #12 on: 23 May 2010, 19:01 »
spot on again today... so bloody hot.
The car loves real hot weather! :undecided:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 23 May 2010, 19:19 »
mine felt like a snail again  :sad:
Offline vwfiend
« Reply #14 on: 23 May 2010, 23:35 »
Do you all actually boot your turbo cars when it's hot!? Your crazy! Mine hasn't been over 3000rpm this weekend, even the evening air is too hot Imo...
Offline Grand Master Patch
« Reply #15 on: 23 May 2010, 23:38 »
Hell yes,fmic ftw :wink:
Offline vwfiend
« Reply #16 on: 24 May 2010, 00:20 »
Surely it'll still be too hot as the air hitting the intercooler is warm as the sun or do you have a mist squirter? What brand if at all is your fmic as the Forge one is nearly £650 which is a lot. Do you know if you can run a charge cooler instead of a conventional intercooler on a golf?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #17 on: 24 May 2010, 05:01 »
couldn't be arsed to do the drop links, the logs were much more important  :smiley:
any good?
throttle angle should be around 82% for full load?
Nick
 01455 617233
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 24 May 2010, 07:09 »
ah ha, therein may lay my problem...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 24 May 2010, 12:33 »
charge cooler would be easy, as long as you have the room for the rad (which you do) you could do it.
With ref to the throttle angle, can someone post up a run off their Golf to confirm? It makes sense though...
